Old 01-20-2010, 11:26 PM
racer965 racer965 is offline
racer965 is on a distinguished road
Default Won't Start!!! Please Help
Hey guys I have a 99 Dodge Ram with a 360 in it. Today I was messing with my driving lights trying to get them to work and install a switch for them. I noticed my cigar lighter, and back up light fuses were blown and changed them I noticed neither worked when i bought it so i was kinda happy i fixed it. Anyway I put a wire into one of the fuse spots for the drving light switch and put the fuse in with it. The other end of the wire ended up hitting a ground and doing something because my radio immediately turned off. Also my high beam indicator, cargo lights, cigar lighter, and dash illimunator are also not working. I checked every fuse in the engine compartment fusebox and in the cab fusebox all are in working order. Also right after it happened I tried starting it and it would start and run for a few seconds then die it did that about four times before i quit and started looking for blown fuses under the hood. Im getting spark. It will crank, i can hear the fuel pump and have gas at my fuel rail. PLEASE HELP THANKS.
Old 01-20-2010, 11:48 PM
Rep:1845
Which fuse were you messing with when this happened/
Old 01-21-2010, 12:11 AM
Did you check the fuses with a test light ? Don't look at them and assume their ok . I have seen small hair line cracks that are extremely hard to see with the naked eye . Check all the fuses under the hood and the on the side of the dash .
Old 01-21-2010, 12:13 AM
I believe it was the blower motor it was one of the big ones all the way on the left and there are only two over there.
Old 01-21-2010, 12:20 AM
I checked everyone of them with a continuity tester I dont understand it.
Old 01-21-2010, 12:22 AM
Rep:1845
Are you talking about the 40A in the PDC?
Old 01-21-2010, 12:32 AM
It was a 10 or 15A. Im not sure wat a PDC is im used to working on old ones. but this was one of the ones on the side of the dash.
Old 01-21-2010, 12:38 AM
Rep:1845
The fuse number would be extremely helpful.
Old 01-21-2010, 12:42 AM
let me try to look it up real quick.
Old 01-21-2010, 01:19 PM
I either had the wire in the Park Lamp Fuse which is a 15A fuse and is number one in the fuse box or the blower motor which is a 10A and number 2 in the fusebox. I also noticed my door buzzer is not working.
