Old 01-19-2010, 01:28 PM
twisted54 twisted54 is offline
twisted54 is on a distinguished road
Default Dash removal
does anyone know where i can find step by step instructions for removing the dash out of my 96 dodge ram 1500? i am trying to change the heater core out and can't see what is holding me up.
thanks----tom
Old 01-19-2010, 01:41 PM
Rep:2640
this is just a guess, a friend just did his '04 ram twice, it took 8 hours the first time
you may need to drop the steering wheel, lay it on the seat, lay the dash down on it, unbolt the heater from inside & then outside, R & R the heater core, reinstall everything
i'm sure one of the other members will tell you for sure
good luck
Old 01-19-2010, 01:55 PM
Rep:1882
INSTRUMENT PANEL ASSEMBLY
WARNING: ON VEHICLES EQUIPPED WITH AN AIRBAG, Refer to PASSIVE RESTRAINT SYSTEMS BEFORE ATTEMPTING AIRBAG SYSTEM OR STEERING WHEEL COMPONENT DIAGNOSIS OR SERVICE. FAILURE TO TAKE THE PROPER PRECAUTIONS COULD RESULT IN ACCIDENTAL AIRBAG DEPLOYMENT AND POSSIBLE PERSONAL INJURY.
  1. Disconnect and isolate the battery negative cable.
  2. Remove the left and right cowl side panel trim.
  3. Remove the knee blocker as described in this group.
  4. Remove the two screws securing the inside hood release handle to the lower instrument panel support.
  5. Remove the screw securing the parking brake release handle to the lower instrument panel support.
  6. Remove the six retaining screws and the lower instrument panel support.
  7. Unplug the airbag wiring connector at the lower left corner of the instrument panel.
  8. Pull the gearshift selector (PRND21) indicator cable and twist to remove it from the position arm on the steering column.
  9. Push tab on bottom of cable retainer up then squeeze sides to remove retainer from column.
  10. Remove the tilt steering column lever, if equipped.
  11. Remove the upper and lower shrouds from the steering column.
  12. Remove the lower fixed steering column shroud.
  13. Loosen the multi-function switch connector screw. The screw will remain in the connector. Remove the multi-function switch connector.
  14. Remove the other steering column connectors.
  15. Remove airbag wiring harness from the steering column wiring trough.
  16. Remove the wiring trough from the steering column.
  17. Remove the three steering column toe plate nuts and washers.
  18. Remove the two nuts and washers attaching the steering column bracket to the instrument panel steering column support bracket
  19. Lower the steering column and allow it to rest on the seat.
  20. Remove the two screws from the bottom of the Airbag Control Module (ACM) cover.
  21. Remove the four screws holding the ACM to the transmission tunnel on the floor.l
  22. Disconnect the wiring at the ACM.
  23. Disconnect the wiring connectors at the left end of the instrument panel.
  24. Remove the screw holding the parking brake release to the bottom of the instrument panel.
  25. Disconnect the wiring connectors at the right end of the instrument panel. There are:
    • Two connectors attached to the heater-A/C housing
    • Courtesy lamp connector
    • Antenna cable connector
    • Two body harness connectors
    • Vacuum harness for heater-A/C system.
  26. Remove the five screws holding the instrument panel to the dash panel.
  27. Remove the lower center instrument panel mounting screw.
  28. Loosen the lower instrument panel pivot bolts.
  29. Roll the instrument panel down.
  30. Using a screwdriver or pointed tool, push through the plastic flashing to release the locking tab on heater-A/C temperature control cable.
  31. Pull the temperature control cable from the top of the heater-A/C housing.
  32. Remove the instrument panel from the vehicle.
  33. Reverse the removal procedures to install. Be certain that all wiring and hoses are not pinched. Refer to Restraint Systems before connecting the battery negative cable. Tighten the hardware as follows:
    • Instrument panel upper mounting screws - 3 Nm (28 in. lbs.)
    • Instrument panel pivot bolts - 12 Nm (110 in. lbs.)
    • Steering column shroud screws - 2 Nm (17 in. lbs.)
    • Steering column bracket nuts - 12 Nm (110 in. lbs.)
    • Toe plate nuts - 23 Nm (200 in. lbs.)
    • Multi-function switch connector screw - 2 Nm (17 in. lbs.)
    • ACM mounting bolts - 11 Nm (105 in. lbs.)
Old 01-19-2010, 02:01 PM
Rep:2640
well, that puts me where i belong, paying the shop to do it,
damn new vehicles any way
Old 01-19-2010, 02:04 PM
Rep:1882
I'm not crazy about pulling dashes either. I'd rather pay someone else to do it!
Old 01-19-2010, 02:21 PM
dodgeman70592's Avatar
Vehicle: 2008 Dodge Ram
Trim Level: Custom
Rep:1648
x2.........
Old 01-19-2010, 08:39 PM
Randy and the rest,thank you for the reply.i am going to start in the morning with your list and check each and everything you posted in the order you have it. i have got to get my truck back on the road again. will post on my progress.
tom
Old 01-19-2010, 09:51 PM
MightyBlueRam's Avatar
MightyBlueRam MightyBlueRam is offline
Vehicle: 2014 Ram 1500 EcoDiezl Laramie
Trim Level: Laramie 4x2
Color: Blue Streak Pearl Coat
Rep:432
MightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really nice
Twisted54, good luck man and if you do this yourself then you are a mean mofo man. I think i'd rather bite the bullet and pay for it. But that's just me being lazy I guess.
Old 01-19-2010, 10:48 PM
I use to hate doing dash work , I was the only mechanic at a body shop and when the dash mounted airbags would blow , guess who got to replace the dashes . It's not so bad , just lay everything out neatly and it goes back together much easier .
Old 11-01-2011, 10:10 PM
RamFan95 RamFan95 is offline
Vehicle: 1995 Ram 1500 4x4
Color: Green
RamFan95 is on a distinguished road
Default Temperature Control Cable
Where exactly should the screwdriver be stuck to release the cable ?
Does the cable just slide out of the plastic housing holding it in place or should the entire plastic housing piece with the cable through it release ?
Thanks
