United Radio
Old 04-12-2011, 01:15 PM
Originally Posted by rclipic View Post
Hey guys. I've read through this entire post and got most of my questions answered but I've still got a few. I've got a 2009 1500 TRX4 with stock 17" wheels, 275 70/R17 tires. I'm looking to get some new wheels and a taller, wider tire. From what I gather from this post, I should be able to do a 35x12.5 tire if I put on a leveling kit. Correct? I've found another site that says to do a 35" tire I would need to lift the truck at least 4". I don't want to have any rubbing but defintely want a taller tire that will stick out a bit more that stock since the TRX4 has fender flares. Also looking for a more aggressive tire and from what I see on this thread I've got a lot of options.
I'd appreciate any help or advice on this since my local tire shops are virtually useless!
I've got 285/75X18 Toyos (34.8" total) with a 4" lift and +18mm offset wheels. It fits just fine but the tire comes REAL close to back corner of the wheel well. The additional height gave me what I needed.
I'd get your local tire shop to do some measuring for you to make sure that if you do go with a wider / taller tire you aren't taking out the flares or fender corners!
Also, that wide of a tire will come pretty close to the inside, maybe rubbing, with stock wheels. Even so, the stock wheel probably won't take a 12.50 tire.
Originally Posted by fishin buddy View Post
i got an 09 dodge ram with 275/60/20 factory stock suspension can i get a 285/65/20 bf goodrich at ko in there with out rubbin issues and no leveling kit or anything if not would a 275/65/20 work? I mainly want to get a lil more height in my tire.thanks for any input
According to the Toyo Open Country A/T specs, an LT 275/65X20 is about 34" & 11" wide so that would be a squeeze height wise.
I couldn't find similar info on the LT285/65X20 but it will be about the same height and should be just 10mm or 0.3937" wider as the 275/65, so that one is a squeeze as well.
Old 04-18-2011, 09:34 AM
xpress00's Avatar
xpress00 xpress00 is offline
Vehicle: 2006 dodgeram 4x4 HEMI
Trim Level: big horn
Color: red
xpress00 is on a distinguished road
wanting to go with a 16 what size do i need for a 35x12.5x16 agresive tire i enjoy the hum wasnt gonna do leveling kit but im thinkin i may have to any combo suggestions
Old 04-20-2011, 08:33 PM
r1500w2004's Avatar
r1500w2004 r1500w2004 is offline
Vehicle: 2004 1500 4wd quad cab
Color: silver
r1500w2004 is on a distinguished road
i have a 2004 quad cab that I am thinking of putting a zone 5 inch kit on..i have 17x 7 steel wheels..I only have so much $ to work with and figured i would reuse the wheels...what would be the max size i could put on them..?
2004 4.7 6000 hid headlamps, airraid cai and filter, bed cover, 2 inch crank on torsion bars,tint
Old 05-14-2011, 02:22 PM
Tmac Tmac is offline
Vehicle: 2009 Dodge Ram 1500
Trim Level: Crew Cab 4x4 Laramie
Tmac is on a distinguished road
I have an 09 1500 Laramie. 2" front/1.5" rear leveling kit going in this week. I have Dick Cepek 35"x12.5" tires and am trying to determine the best wheels.
I like the look of the Eagle Alloy 064. They are 20x10 with 4.64" bs and a -21 offset. The garage that's doing the work is concerned they will rub the fender wells. They are suggesting a 20x9 wheel with bs closer to 5" for better fit.
My alternative is the Eagle Alloy 079. They are 20x9 with 4.64" bs and a -12 offset.
Any comments on these fitting or rubbing would be appreciated.
Old 05-30-2011, 05:41 AM
clint's Avatar
clint clint is offline
Vehicle: 2011 dodge ram 1500 sport
Color: deep water blue
clint is on a distinguished road
Default need help guys
i just put on a 2" levelling kit on my 2011 ram 1500 sport. my question to you ( Bighorn or Scat preferably...lol) is what should i or could i put under it for boots?? was thimking moto metal 20's with 305s or should i go with a smaller rim like a 17 or 18 inch rim and bigger rubber. all opinions would be helpful from everyone. just want something that will fill the wells in and look sweet. ps i took the bug deflector off lol.
Old 07-15-2011, 03:49 PM
BooBear185's Avatar
BooBear185 BooBear185 is offline
Vehicle: 2004 Dodge Ram 1500
BooBear185 is on a distinguished road
@ BigHorn 4 Life
Holy crap a 9" lift on your truck.......... Do u have to taking a running leap to get in to it? Now for the serious question, where would I go to find Nitto tires?
Old 07-15-2011, 04:01 PM
BooBear185's Avatar
@ScatPak07
Dude I love your truck........ 1500, 2500 ??? I a going to be getting the 2 leveler kit for my 1500. I never noticed how the fron dips down till I saw the pics on here and I went to the Bloomsburg Truck Jamboree for the first time last weekend...... there were some totally AWESOME trucks there. Can I PM you? I would like to get some repair info from you
Old 07-15-2011, 04:16 PM
BooBear185's Avatar
@Infernogrl6
Girl you could put 44's under that thing w/o a problem........ GOOD LORD are you building yourself your own battering RAM to fight traffic on the Island Expressway??? LOLOLOLOL
Old 07-15-2011, 04:39 PM
BigHorn 4 Life's Avatar
Color: Briliant Black
Rep:463
Originally Posted by BooBear185 View Post
@ BigHorn 4 Life
I did before I had the steps instaled haha.
You can get Nitto's from Discount tire.
Old 07-15-2011, 10:29 PM
rclipic's Avatar
rclipic rclipic is offline
Trim Level: TRX
rclipic is on a distinguished road
I was torn with the same question for mine. I liked the 20" wheels but like the look of taller rubber. My choice was easy because the wheels I chose only came in 18". I went with Billstein 5100's to level the front, 18x9 wheels with a -11 offset and 35x12.5 Nitto Trail Grapplers. Looks awesome. Did it three weeks ago and still getting compliments!
Bottom line, I'm not sorry I went with the 18" wheels but I think either way looks good.
