Old 02-23-2011, 05:23 PM
tbeaton tbeaton is offline
Vehicle: 11 2500 4x4
Rep:14
tbeaton is on a distinguished road
Originally Posted by dodgeeric View Post
I recently have had the opportunity to purchse a set of 315/70/17 BFGs off a friend whom has less than 2k miles on them. I run 17" wheels on my truck already and thought this might be a good deal. I do not wish to lift my truck but would love to have bigger than 265s on it. My question is, can I comfortably run 315s on stock suspension without a leveling kit, or are these too tall?
that size is essentially a 35. your going to need a lift.
11 deep water blue 2500 big horn, 5.7 hemi, 4.10 gears, 6" bds short arm lift, 20x9 -12 offset kmc hoss black wheels, 37x12.5x20 nitto trails, n fab cab length nerf bars, banks muffler w/ lou's custom tubing, pocket flares, top gun customz dual steering stabilizer, mission sled deck.
Old 02-23-2011, 08:36 PM
BigHorn 4 Life's Avatar
Color: Briliant Black
Rep:463
Yes you will need to lift your truck for those tires bro.
Old 02-23-2011, 10:46 PM
ScatPak07's Avatar
Rep:970
Yes you will need to do something to the trucks height to fit those 315/70/17s. You should be able to get by with a leveling kit since they are not a full 35" tire. You will need some wheel spacers as well to avoid any rubbing on the suspension components
Old 02-24-2011, 01:28 AM
DodgeRamSTCREW2010 DodgeRamSTCREW2010 is offline
Vehicle: 2012 Dodge Ram
DodgeRamSTCREW2010 is on a distinguished road
Hey guys, I know im coming in way late in this conversation, but after reading all of your post I got alot of my questions I have had for a year answered. The bad part is that I just ordered Hankook Dynapro ATM RF10 for my truck. I ordered 275/60/20 and they will be going on my American Racing 20" Chrome wheels I got for them. I do have a Rough Country leveling kit installed 2.5 (front) 1.5 (rear). I didnt realize I could put a bigger tire on after installing that leveling kit. Will the tires and wheels I have still look good because they are the stock 20" size? Im worried about this now after reading everyones post. Thanks for your input.
Old 02-25-2011, 02:11 PM
Rammin's Avatar
Rammin Rammin is offline
Vehicle: '03 Dodge Ram 1500 2wd
Rep:44
Rammin is on a distinguished road
Yeah they're going to look a little small since it's a stock tire size on non-lifted trucks.
Old 02-25-2011, 02:31 PM
Infernogrl6's Avatar
Infernogrl6 Infernogrl6 is offline
Vehicle: 06 Dodge Ram Hemi!
Color: Inferno Red
Infernogrl6 is on a distinguished road
Hi,
I can't seem to find out info about tire size for my truck.
Right now I have 2006 4WD 3" body lift with stock size nittos
I understand I can fit 35's on them, but I would like them to stick out a little bit, I guess that would be called the negative?
Can you explain what size tire I need to buy, to give my truck the most aggressive look with them sticking out a little.
Going with Toyo Open Country with 17 or 18 American Eagle Alloys.
Then..here is another issue
What size would I need if I add a 6" suspension lift on top of the body lift.
Thanks for the help!
Old 02-25-2011, 05:11 PM
Rammin's Avatar
Rep:44
By adding a 6" kit on top you could easily clear 37s or bigger. The thing with the tires sticking out past the fenders really depends on the wheels and the backspacing or called offset. Anywhere from -12 to -20 negative offset or around 4.50 backspacing will stick the tires out a couple inches past the fender. Plus when you lift your truck higher you'll need some extra backspacing to clear the suspension components or some spacers for your current wheels.
Old 02-26-2011, 03:13 PM
who10 who10 is offline
Vehicle: 2006 Dodge Ram
Color: Charcoal
who10 is on a distinguished road
I have a stock 2006 1500 4X4. Do you think I can run 285/70/17 with no rubbing problems?
Old 03-15-2011, 05:01 PM
firerescuedodge23's Avatar
firerescuedodge23 firerescuedodge23 is offline
Vehicle: 2007 Dodge Ram1500
Trim Level: SLT (ThunderRoad)
Color: Gold
Rep:59
firerescuedodge23 will become famous soon enough
Default Need some info help
I just put a 2.5 level kit on my 07 2wd 1500 and im trying to see whats the largest tire i can run on the stock 20's. the guy at 4wheelparts.com told me 275/60/20.....but thats what im running right now stock and theres more than enough clearance for something bigger in my opinion but i want some knowledge from someone who actually knows for sure what they're talkinga bout so PLEASE HELP ME
AFE Stage 1 intake, Flowmaster 40 series exhaust, Fabtech 6 inch lift, 3 inch PA body lift, 35x12.5x20 Federal Couragia M/t, Full audio system, LSD, HIDs, Superchips Cortex, 20x10 XD Strike -24 offset
Old 03-15-2011, 05:22 PM
275's are not the max width you can run. I bet you can run a 285 section width tire on the stock wheels with no rub given your leveling kit. I also am certain you can go up to a 70 aspect ratio, just a bit taller than you have, and still not rub in the front. Beyond that, a different wheel with a different offset will be needed if you want to go to a wider tire. Also, anything taller than a 70 series tire will need a lift.
I'm running 285/75X18's on a wheel with +18mm offset and a 4" lift. those tires are 34.7" tall.
