Old 02-11-2011, 08:52 PM
Lordgwydion24 Lordgwydion24 is offline
Vehicle: 2006 Dodge Ram 1500
Lordgwydion24 is on a distinguished road
Originally Posted by UltraFlame View Post
My thoughts after I wear out my rubber (Cooper Discoverer Tires) is that when I replace them I will be putting on a 35" Nitto Terra Grapler tires on my Monster XD's. I have a 2" leveling kit on the front and I am really hoping that I don't have any rubbing issues. Really don't want to put on any spacers. So who can tell me exactly what size tire I will need. I currently have 275-60-20 and I am thinking 315-60-20 or 325-60-20.
I have the Nitto Terra Grappler All Terrains. They're 305/55/20. I also have a 2" leveling kit and I haven't seen any problems. Good tires so far too. I'm fairly happy with them.
Old 02-11-2011, 11:01 PM
ScatPak07's Avatar
Rep:970
Originally Posted by tbeaton View Post
quick question on the short arm vs long arm lifts for the 2500. looking at the 6" or 8" lifts, just wondering if the long arm is necessary? i don't like how you have to completely remove the factory control arm mounts. 6" should clear 37's without trimming correct?
yea on a 2500 a 6" lift can fit 37" tires. Only thing you have to worry about is the whole rim and tire width issues. that being you would need to make sure the tires dont rub on the suspension. that can be fixed with either wheel spacers or an aftermarket wheel with a negative offset. You can always install everything and see if there was rubbing, then you can fix it if there is
Old 02-12-2011, 06:13 AM
UltraFlame's Avatar
Vehicle: 2007 Dodge Ram Quad
Rep:840
The 305/55/20 (33.2" dia) is almost the same tire size as the 275/60/20 (33.0" dia). A 315/60/20 would give me a 34.9" dia, the sidewall goes from 6.5" to 7.4", and the Radius goes from 16.5" to 17.4".
Old 02-14-2011, 04:56 PM
tbeaton tbeaton is offline
Vehicle: 11 2500 4x4
Rep:14
tbeaton is on a distinguished road
how about peoples opinion on the tuff country 6" lift. has long arms that don't require the removal of factory control arm mounts. thats huge in my book.
11 deep water blue 2500 big horn, 5.7 hemi, 4.10 gears, 6" bds short arm lift, 20x9 -12 offset kmc hoss black wheels, 37x12.5x20 nitto trails, n fab cab length nerf bars, banks muffler w/ lou's custom tubing, pocket flares, top gun customz dual steering stabilizer, mission sled deck.
Old 02-14-2011, 06:56 PM
BigHorn 4 Life's Avatar
Color: Briliant Black
Rep:463
If you mean the rough country lifts I am not too impressed with them myself.
Old 02-14-2011, 11:12 PM
Rep:14
nope tuff country. http://www.tuffcountry.com/
they make a 6" long arm kit that does not require you to remove the control arm mounts.
Old 02-15-2011, 12:03 AM
Rep:463
Ya that lift looks good.
Old 02-15-2011, 10:25 AM
Rep:14
i see in your sig that you put a 2" spacer on your 6" lift. what else did you have to do to the 6" lift?
Old 02-15-2011, 02:14 PM
Rep:463
Thats all I did to the lift.The only reason i added the spacers was because of the nose dive it had.When i got my lift the lift for these trucks were new.They didn't know about the rake difference and neither did i.So now you can get the BDS in a 3" rear lift or a 5".I have the 5" so I had to get the spacers to level it a bit.I love the way my truck came out .I am getting my flares painted next month too .
Old 02-15-2011, 05:28 PM
Rep:14
what back spacing are your wheels to fit a 20x10?
