Old 01-29-2011, 04:17 PM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
hey all im going to be putting a ready lift 2.5 up front and 1.5 rear here soon hopefully and im going to be getting new 20inch rims in the spring with some mud tires and the kit says you can run a 35' but i think thats too big im leaning more towards a 33' what do you all think???
Old 01-31-2011, 10:09 PM
buckchaser91 buckchaser91 is offline
Vehicle: 2006 dodge ram 2500
Trim Level: slt thunderroad
Rep:40
buckchaser91 is on a distinguished road
i have a 06 2500 hemi im going to put the 2inch leaveling kit should i be able to fit a 35 by 12.50 tire with a 17"x9 with -12 offset
Old 01-31-2011, 10:16 PM
ScatPak07's Avatar
Rep:970
You should be able to fit what they recommend. If you are getting some aftermarket wheels then look at getting a negative offset. If you do that then you should be able to fit the 35s.
Yes you will definitely be able to fit that size tire. Your suspension is HD so you already sit a couple inches taller then a 1500. If you level it then you will for sure be able to fit some 35s
Old 02-01-2011, 07:33 PM
Rep:713
oh ok thanks bud..much appreciated
Old 02-01-2011, 07:59 PM
Rep:40
id also like to thank you. i was pretty sure id be able to fit but want some other thoughts. now i just gotta go spend the money the hard part.
Old 02-02-2011, 05:53 PM
warwickram's Avatar
warwickram warwickram is offline
Vehicle: 09 ram 1500
Trim Level: laramie
Rep:38
warwickram is on a distinguished road
will 285 50 20 fit a stock 07 1500 nitto grapper or is another size be better
Old 02-06-2011, 01:51 AM
ScatPak07's Avatar
Rep:970
Ya those will definitely fit the truck. To be honest I think a bigger tire would be a better idea. That measures out to be a 31" tire which seems a little small. Take a look at the Nitto Durra and Terra Grappler they make a 275/60/20 which should fit your truck. It measures out to be almost a 33" tall tire but the width is narrow enough to fit without any worries. You can even add a leveling kit to that and it will look good.
Old 02-07-2011, 10:04 PM
spamn spamn is offline
spamn is on a distinguished road
I know that everyone hates these questions but there are so many variables and it's a costly decision to make..
2006 1500 TRX4 with 2" level. I am not worried about height, but rub on the UCA. I would like to get the largest tires that will fit. Willing to get aftermarket wheels if necessary. With 4.5" backspacing do I still need to get a negative offset? Would like to squeeze 33x12.5s on if possible with zero rub.
Old 02-08-2011, 07:52 PM
ScatPak07's Avatar
Rep:970
The offset is the amount the tire is shifted inward or outward. The stock rims have a +20mm offset, so if you get a 0 offset rim you will go outward 20mm. If you go with a negative then you will be just fine with the tire width. I would recommend going with a negative offset since the truck will look really aggressive sine the tires are sticking out
Old 02-09-2011, 03:45 PM
tbeaton tbeaton is offline
Vehicle: 11 2500 4x4
Rep:14
tbeaton is on a distinguished road
quick question on the short arm vs long arm lifts for the 2500. looking at the 6" or 8" lifts, just wondering if the long arm is necessary? i don't like how you have to completely remove the factory control arm mounts. 6" should clear 37's without trimming correct?
11 deep water blue 2500 big horn, 5.7 hemi, 4.10 gears, 6" bds short arm lift, 20x9 -12 offset kmc hoss black wheels, 37x12.5x20 nitto trails, n fab cab length nerf bars, banks muffler w/ lou's custom tubing, pocket flares, top gun customz dual steering stabilizer, mission sled deck.
