Old 05-15-2014, 04:41 PM
paulturner911 paulturner911 is offline
Vehicle: 2004 Dodge Ram 2500
Engine: 2004-2004 359ci (5.9L) Cummins ISB 600 24-Valve Diesel I6 325hp 600lb/ft
paulturner911 is on a distinguished road
Default Fitment
I have an 04 2500 4x4 Cummins, no lift and am running a stock wheel on 315/70/17 that rubs....
I want to run a 20x10 with meat on it and not rub, BUT I dont want to lift the truck.
What are my options?
Thanks
Old 06-11-2014, 10:02 PM
TRIPLETED TRIPLETED is offline
Vehicle: 2006 Dodge Mega Cab 5.7 HEMI
Trim Level: SLT 4x4
Color: INFERNO RED
TRIPLETED is on a distinguished road
Has anyone installed CARLi rear long travel air bags . I have 2006 5.7 hemi 4x4 solid American axle . Was told all 1500 mega cab have 4" factory lift is that true . Thanks for any help
Old 06-19-2014, 12:37 PM
Balkin6 Balkin6 is offline
Vehicle: 2006 5.7L SLT Big Horn 4x4
Trim Level: SLT big horn
Balkin6 is on a distinguished road
Anyone know if I can level the front 2.5" and buy adapters for the ball joints ? I want to raise the front but don't want to buy a whole suspension lift kit just to raise the front up some.
Old 06-20-2014, 11:56 PM
dodge23 dodge23 is offline
Vehicle: 2012 Dodge Ram 1500 Sport
dodge23 is on a distinguished road
anyone know how much a 18x9 +1 offset will stick out past the fenders? and truck also has stock fender flares, would like to get them flush of little past them?
Old 09-01-2014, 11:23 AM
OpnCskt's Avatar
OpnCskt OpnCskt is offline
Vehicle: 2014 Ram 2500
Color: Black Apearance package
OpnCskt is on a distinguished road
I have the 2014 Ram 2500 4x4 with the Black Appearance package and the Wheels aren't bad. So I plan on using them for a bit. If I level the front can I fit 35x12.5 TOYO Open Country M/T on the stock wheel? Or should I wait until I get Aftermarket 20x10 offset wheels?
Old 09-03-2014, 10:16 PM
Dodgey24's Avatar
Dodgey24 Dodgey24 is offline
Vehicle: 2014 RAM 1500
Trim Level: Express Regular Cab
Dodgey24 is on a distinguished road
You could fit them on the stock rim but it isn't recommended and you might have some funny wear if the air pressure is out of whack. You would definitely need some sort of a wheel spacer in order to clear the upper control arm. It could be as little as 0.25" but probably a little more. I also hear that it varies truck to truck on whether you will rub with a 35" tire on just a level. You just dont want to rub on the lower inner fender as there isnt much trimming you can do without grinding away the body panel.
Sorry if I wasnt more help but bottom line, you can fit the tire on the wheel but will most likely need a 2.5" level and wheel spacers.
6" Zone Lift w/ Zone Upper Control Arms, Bilsteins @2.8, 37x13.5X18 Toyo M/T's, Fuel Trophy (Anthracite) 18x10 -12mm offset, Trinity T1000, Kenwood DNX691HD, 12" Kicker Sub, Kicker/Alpine speakers, BT Catch Can, Smoked LED Tails and 3rd brakelight and tailgate bar, 14" Mufflex with 5" tips, 35% tint
Old 09-21-2014, 01:42 PM
OpnCskt's Avatar
I think I'll play it safe and level it out then get a set of offset wheels with 35" tires. Thanks for the help!
Old 09-21-2014, 09:47 PM
Post pics when done
If you need assistance let us know too!
