Old 09-19-2012, 01:18 PM
Hey Drex!
Grab if you are not looking to stick out a whole lot but want to stick out a tad, go with the -12 offset.
You will stick out 2"-2.3" but on a lift that is perfect
-24 will have you out about 2.5"-2.8"
Neither look bad, it just depends on the look you are looking to obtain.
Also, ask yourself if you will run flares down the road and if so what kind.
That will play a factor too on a decision of offset.
-12 offset, you can run OE/OE style flares and it will be almost flushed.
-24 offset and you can begin to look at the pocket style flares.
-12 offset on a pocket style flare will have the wheels tucked under and I am sure you do not want that.
So this also plays a factor in your decision.
But the wheels you want come in both those offset.
click here --->***Tuner and Muffler Sale*** <---click here
Old 09-19-2012, 01:32 PM
Drex851 Drex851 is offline
Vehicle: 2009 Dodge Ram 1500
Trim Level: Slt
Color: Grey
Rep:21
Drex851 is on a distinguished road
Hey Drex!
Thanks again fast, just wasn't sure if the -12 was going to be cutting it close to the suspension
Old 09-19-2012, 01:35 PM
Trim Level: Slt
Color: Grey
Rep:21
Yea u know what, I actually like the flares that big horn has, I might do those
Old 09-19-2012, 01:47 PM
Not at all....That is equivalent to a 5" backspace.
I have a 20x9, 0 offset/5" backspace on 37's and I have 1" to the control arm and zero rub anywhere else.
Old 10-02-2012, 06:02 PM
OfcrFr's Avatar
OfcrFr OfcrFr is offline
Vehicle: 2007 Dodge Ram
Trim Level: SLT Big Horn
Rep:27
OfcrFr is on a distinguished road
So I have read this thread from front to back, there is a lot of great info on here that answered almost all of my questions. I just want to make sure my new tire purchase will fit my current set up. So here it is...
2007 Big Horn 4x4 with the factory 20x9. I will be adding the HBS 2.5 level up front, (I want to keep close to an OEM look just a beefy leveled appearance) I was going to get the 33x12.50r20 either Toyo OC M/T's or Nitto Mud Graps, I know you need spacers for 35" but I dont like the stuffed look with the leve. Will I still need spacers with the 33" tires? If so do I need them on all 4 wheels? If I dont need the spacers can I still put them on the rear without causing any issues? (I like a little poke).
Thanks in advance guys this forum has given a first time truck modder alot of good info on everything. Time to get out of the shadows I guess and start getting some pictures up!
DD and Tow Pig lol-2007 Ram, HEMI, Big Horn, 3.92 gears (open dif) 295/60/20 Nitto Trail Graps, Bilstein 5100s maxed, 18 inch Magnaflow SI/SO with 4 inch tip, Mods added all the time.
Old 10-02-2012, 06:56 PM
Anything wider than 285/xx/20, will require a spacer of some sort
There is no way around this
Old 10-02-2012, 07:52 PM
OfcrFr's Avatar
Rep:27
Thanks man! Thats what I thought. just making sure before I throw $1500 dollars down
Old 10-02-2012, 08:06 PM
No Problem!
Old 10-22-2012, 08:46 PM
vguaman87 vguaman87 is offline
Vehicle: 2007 Ram 1500 Quad Cab
vguaman87 is on a distinguished road
i have a 07 1500 ram QC. its getting a 2" daystar level kit in the front and a 2" block in the back next week. can i fit 35" tires? im looking to get aftermarket 20' wheels as well. any advice would be appreciated.
i was looking at nitto terra grappler AT's in 275/65/r20. i think that comes out to about a 34.1. i was wondering if i could to bigger?
thanks, looking to purchase the wheel/tire combo today or tomorrow so feedback will be great guys
Old 12-29-2012, 12:29 AM
aedwardzo aedwardzo is offline
Color: Light Graystone
Rep:57
aedwardzo will become famous soon enough
Great info here guys!
mods..... Too much to list! check my mod list!
http://www.ramforumz.com/member.php?u=58666
