Old 12-09-2011, 05:25 AM
ramhemisport2004 ramhemisport2004 is offline
Vehicle: 2004 dodge ram
ramhemisport2004 is on a distinguished road
Anyone had any experience with 295 tires?? I know its not very common but I'm about to commit to a set of 295/60/20 trail grapplers on my level '04, stock 20's. I know Nitto lists the tire as 34.45" x 12.13". I've seen an '07 with these tires and 1/4" spacers but I've heard that '03-'05 are slightly different, any insight?
Old 02-09-2012, 05:14 PM
Funzy32 Funzy32 is offline
Vehicle: 2005 Dodge Ram 1500
Trim Level: Quad Cab Hemi
Color: Grey
Funzy32 is on a distinguished road
Default 2005 Ram 1500 Quad Cab Hemi
I am looking at putting a 2" Level kit in front. What should I do as far as tires size and rim size? From what I have read in the forum, I can level and go with 20" aftermarket wheels with 35x12.50x20 Tires. Will this deff. work? If so, what spacers or anything would I need to do this? Thanks for the help.
Old 03-12-2012, 11:29 PM
mopar04 mopar04 is offline
Trim Level: larmie
Color: blue
mopar04 is on a distinguished road
i have 04 ram 1500 2wd with 8in lift and 3in bodylift with stock 20s and inch and half spacer what would be a good tire size ?
Old 04-14-2012, 02:18 PM
smellit94 smellit94 is offline
Vehicle: 2005/dodge ram/2wd
Color: grey
smellit94 is on a distinguished road
hey got to ask will 34s fit on my dodge ram 1500 2wd im putting a 3 inch suspension kit on from rough country?
Old 04-26-2012, 10:34 PM
stef0703's Avatar
stef0703 stef0703 is offline
Vehicle: 2010 dodge ram 1500
Color: BLUE
stef0703 is on a distinguished road
hey i have a 2010 dodge ram 1500 slt. got a flat in my stock tires 275/60r20 so time to upgrade.
im wondering what i will need as parts if i want to run 35 x 12.50r20 nitto trail grapplers on KMC XD SERIES SPY 797?
Old 04-27-2012, 10:37 AM
Dodge4315's Avatar
Dodge4315 Dodge4315 is offline
Vehicle: 2011 Ram 1500
Dodge4315 is on a distinguished road
I had 295/65r20 Trail Grapplers (35.47x12.13 according to Nitto) with leveling kit on the factory wheels and needed 1/4 wheel spacers to avoid rubbing. I ran 305/55r20 Terra Grapplers (33x12.6) with +.18mm offset wheels and had rubbing at full turn on my leveled 2007 Ram 1500. My buddy has the same set up on his leveled 2011 Ram 1500 SLT and he also has rubbing at full turn.
Here is a pic of my truck with the Readylift leveling kit (2.5 front, 1.5 rear) and 295/65 Trail Grapplers on factory 20" wheels and 1/4 spacers. No rubbing issues, but NO room for travel if going offroad.
10" lift, 37x13.5 Toyo MT's on 20x10 Fuel Hostages, 4.56 gears, and more..
Old 05-13-2012, 01:14 PM
sean sean is offline
Vehicle: 1997 Dodge Ram 1500
Color: red
sean is on a distinguished road
hey i got a 97 ram thinking of putting a 3" rough country lift on but will i be able to 35" tires or go with the 33" it says? http://www.roughcountry.com/dodge_4wd_94-01_3.html
check it out
Old 05-18-2012, 10:51 AM
2010bluesport's Avatar
2010bluesport 2010bluesport is offline
Vehicle: 2010 Dodge Ram 1500 Sport
Trim Level: sport
Color: blue
Rep:22
2010bluesport is on a distinguished road
Hey fellas. I just ordered a Bilstein level kit and am going to put some new shoes on it. I am going with the Fuel Throttles, but my question is what size should I go with that will not rub? I am wanting to go with the 295/55/r20 or 305/55/r20 Trail Grapplers. Will the 55 height look stupid and not be tall enough? Also, what offset should I use? I am thinking -12mm. Help would be greatly appreciated.
Treat Me Good, I'll Treat You Better; but
Treat Me Bad, I'll Treat You Worse!
Old 07-14-2012, 01:46 PM
Attachment 27519
Im thinking of running with the same....295/60/20 but Terra's. I have read there is no rub vs the Trails.
They say because the trails are more aggressive on the side treads? it makes sense....any ideas?
Old 07-19-2012, 06:13 PM
jorian85 jorian85 is offline
Vehicle: 2012 1500 CC Laramie
jorian85 is on a distinguished road
2012 1500 4x4 Laramie, 33x12.50R20 Toyo Open Country M/Ts on stock wheels. I added 5/16" wheel spacers all around, No lift and No level. VERY VERY slight rubbing on upper control arm. You can't hear or feel the rubbing but if you look at the tire and control arm they have a small spot thats always clean on the driver side.
