Old 12-22-2009, 01:27 PM
57Hemi08's Avatar
57Hemi08 57Hemi08 is offline
Vehicle: 2008 Dodge Ram
Trim Level: SLT Big Horn
Rep:42
57Hemi08 is on a distinguished road
Post Suspension, Tire, and Wheel Guide
Thought I would start this to help answer a lot of questions. Please don't post in this thread to keep from having page after page that somebody has to read through to find an answer. PM or email me with any information you have to fill in the question marks, add, or correct any information and I will update this post. If you have any year model dodge and know what size wheels and tires came stock on it, backspacing, bolt pattern, etc., what size tires and wheels you have on it now and what you did to get them to fit leveling kit, lift, spacer, etc let me know by PM or email. For example just shoot me a PM that says: 2008 Dodge Ram 1500 4wd, stock 275/60R20 bolt pattern 5on5.5 backspacing 5.5", currently running 35x12.5R20 to make them fit you need 2"+ leveling kit and 1/4" spacer. If you have a really good picture of it email it to me or if you have it on this forum send me a link and I'll post it to give people and idea of what their truck will look like with x year model dodge with x lift and x tires.
06-08 4wd
Stock suspension: front - struts, rear - leaf springs
Stock tires: 275/60R20, ?R18, 265/70R17
Stock wheels: 20x9 5on5.5 backspacing ?, 18" 5on5.5 backspacing ?, 17x8 5on5.5 backspacing ?
2"+ leveling kit:
stock 20" & 18" wheels and 1/4" spacer - 35x12.5 tire
aftermarket 20" wheel max backspacing 5.5" - 35x12.5 tire
aftermarket 18" wheel max backspacing 5" - 35x12.5 tire
4" lift:
6" lift:
aftermarket 20" wheel max backspacing 5.5" - 37x12.5 tire
aftermarket 18" wheel max backspacing 5" - 37x12.5 tire
02-05 4wd
Stock suspension: front - torsion bars, rear - leaf springs
Stock tires:275/60R20, ?
Stock wheels: 20" 5on5.5 backspacing ?, 18" 5on5.5 backspacing ?, 02-03 17x7 Steel 5on5.5, 02-03 17x8 Aluminum 5on5.5 backspacing 5 9/16", ?
2"+ leveling kit or crank torsion bars:
4" lift:
6" lift:
94-01 4wd
Stock suspension: front - coil springs, rear - leaf springs
Stock tires: ?
Stock wheels: 94-99 16x7 Aluminum 5on5.5 backspacing 5" offset +13.97mm, 00-01 17x7 Steel 5on5.5, 00-01 17x8 Aluminum 5on5.5 backspacing 5 9/16", ?
2"+ leveling kit:
stock ? wheel - 33x12.5 tire
aftermarket ? wheel - 33x12.5 tire
5" lift:
aftermarket ? wheel - 35x12.5 tire
7" lift:
aftermarket ? wheel - 38x12.5 tire
94-08 2wd
Stock tires: ?
Stock wheels: 94-99 16x7 Aluminum 5on5.5 backspacing 5" offset +13.97mm, 00-03 17x7 Steel 5on5.5, 00-03 17x8 Aluminum 5on5.5 backspacing 5 9/16", ?
94-01 2"+ leveling kit:
00-01 3" lift:
02-05 3" lift:
02-05 6" lift:
Good list of manufactures of lift kits: http://www.rockymountainsusp.com/
Good site with information on wheel dimensions, backspacing, offset and bolt circles: https://www.rsracing.com/tech-wheel.html [MADDOG]
Old 12-22-2009, 01:30 PM
57Hemi08's Avatar
Rep:42
2008 Dodge Ram 1500 4wd, 2.5" leveling kit, 35x12.5R20 Nitto Mud Grapplers
Old 01-07-2010, 08:54 AM
warhead47 warhead47 is offline
Gender: Not Specified
warhead47 is on a distinguished road
I have an 09...I take it that you used a 1/4 inch spacer with stock rims and im wondering if it would be the same on an 09....brakes are huge.
Old 01-07-2010, 10:56 AM
57Hemi08's Avatar
Rep:42
Yeah they are the stock 20" wheels with a 1/4" spacer. My tires were rubbing the front sway bar slightly. Assuming the sway bar is in the same place and the stock 20" wheels have the same backspacing then you will probably need a 1/4" spacer. The brakes on my 08 are huge too.
Old 02-02-2010, 07:06 PM
sablefish's Avatar
sablefish sablefish is offline
Vehicle: 2013 ram sport
Trim Level: sport
Color: red
Rep:78
sablefish will become famous soon enough
ba........bump
2013 ram sport, 8 speed. pace edwards full metal jack rabbit tonneau, bed slide 1500cg bedslide, husky weatherbeaters
Old 04-12-2010, 12:00 PM
Silver05Ram's Avatar
Silver05Ram Silver05Ram is offline
Vehicle: 2005 Dodge Ram
Rep:98
Silver05Ram will become famous soon enough
[QUOTE
02-05 3" lift:
02-05 6" lift:
aftermarket ? wheel - 35x12.5 tire[/QUOTE]
In a way this is wrong. I have a 2wd 05 1500 with no lift or level and I'm running 35's by 12.5 on a 20" rim. No rubbing issues whatsoever.
35" Mickey Thompson ATZ's/stock 20's painted black. Tinted Tails. Dynomax Bullet Resonator. LED's inside cab. Debadged. 12k Hid's
Old 04-12-2010, 10:57 PM
I push the skinny pedal
Rep:3277
you're the exception to the rule then, some people just have all the luck. Most 35s rub at full turn on the rams at stock height.
Kurtis
Old 04-13-2010, 04:28 PM
Rep:98
hmm who knows. I guess my truck was the factory freak of the 05 2wds. Lol jk.. I'm going up 3 inches in the back and about 4.5 in the front and I'm gonna throw some 37's on there with wheel spacers to see how they fit. My gut says theyre not going to fit
Old 01-06-2011, 11:07 AM
UltraFlame's Avatar
Vehicle: 2007 Dodge Ram Quad
Rep:840
My thoughts after I wear out my rubber (Cooper Discoverer Tires) is that when I replace them I will be putting on a 35" Nitto Terra Grapler tires on my Monster XD's. I have a 2" leveling kit on the front and I am really hoping that I don't have any rubbing issues. Really don't want to put on any spacers. So who can tell me exactly what size tire I will need. I currently have 275-60-20 and I am thinking 315-60-20 or 325-60-20.
Old 01-06-2011, 11:18 AM
Rep:1625
What's the offset of your XD's?
