Old 11-23-2009, 12:28 AM
Ram062500 Ram062500 is offline
Ram062500 is on a distinguished road
Default HID headlight in 06 ?
hey i am new to the site and i am wonderin if anyone has had problems with aftermarket HID lights messin up the computer in a newer ram. I have a 2006 ram 2500 and already have had the computer turn my low beams off due to the plow lights. will the HID kits affect the computer and turn them off again or what do i have to do to make them work so the computer doesnt get messed up again
Old 11-23-2009, 01:54 AM
I push the skinny pedal
Rep:3277
I can't say I've heard of HIDs messing up the computer before; maybe you have a bad short somewhere causing this problem. Just to clarify, when you're running your low beams and fog lights together, the low beams turn off?
Also, don't forget to fill out your UserCP so we can have some info about your truck for future reference; and stop by the newbie section to say Hi.
Kurtis
Old 11-23-2009, 08:21 AM
thanks i will have to stop by there but the reason they shut off once is cause i have a plow on the truck and has a diffrent bulb for plow lights and the computer one day shut the low beams off and dodge say it was the plow light sending a diffrent watt code back and it shut them off. i jus dont want to put them in and have it do it again and have to pay to get the headlights turned back on
Old 11-23-2009, 02:57 PM
Rep:3277
Ok, I think I see it now. Your plow lights may be causing too much drain on your system so the PCM shuts down the lowbeams in favor of the plow lights. I don't really have any ideas how to get around that, hopefully someone else can chip in here.
Kurtis
Old 11-23-2009, 03:16 PM
dodgeman70592's Avatar
Vehicle: 2008 Dodge Ram
Trim Level: Custom
Rep:1648
run straight to the battery with a relay
Old 11-23-2009, 08:18 PM
where do u run the relay kit to and do u need to get a special kit. the ones i ordered have both high and low beam hid in one bulb.
Old 11-24-2009, 09:19 AM
Trim Level: Custom
Rep:1648
Look at 3B specialties website, there are diagrams on wiring HIDs for Rams on there. They are also a supporting vendor here and make some great products. Contact them, they will help ya out
Old 11-26-2009, 05:12 PM
i was lookin into the wiring on the one website they have it for 02-05 looks like it needs the relay so does anyone have them in a 06 to 09 and has had to do this or no or should i jus make a relay kit jus to be safe.
