United Radio
Old 11-07-2009, 03:15 AM
I push the skinny pedal
Rep:3277
Thumbs up AAC LED strips
Hey guys, well now that I have the new roll pan painted and installed on my truck, I need some light on the plate to keep it legal. I ordered the Oracle exterior white LED strip which I installed this evening.
To set it up I had to cut the strip and solder on some wires which I'd previously cut off of the old liscence plate lights. I then drilled a small hole in the top of the plate well and installed 1.5" of LED strip by using the 3M sticky back and threaded the wires to the back of the roll pan and spliced them into one of the old plate lights. The exposed soldered connection will be getting some black liquid electrical tape tomorrow to protect the wires and blacked them so they blend in better.
I'll post some daytime shots tomorrow so you can see the setup. As well i'll be installing the AAC 3157 LEDs into my front turnsignals.
Kurtis
Old 11-07-2009, 09:36 AM
dodgeman70592's Avatar
Vehicle: 2008 Dodge Ram
Trim Level: Custom
Rep:1648
Very nice sir, very nice
Old 11-07-2009, 10:22 AM
Sparky's Avatar
Sparky Sparky is offline
Vehicle: '06 Ram Quad Cab HEMI
Color: FLAME RED
Rep:23
Sparky is on a distinguished road
That looks sweet, cant wait to see day time pics.
Old 11-15-2009, 09:14 PM
4matty3 4matty3 is offline
Gender: Not Specified
Rep:49
4matty3 is on a distinguished road
yo i have the same thing but 1 foot and red but i cant figure out how to get the wires in there? any tips
[IMG]http://i602.photobucket.com/albums/tt110/4matty3/random044-1.jpg[/IMG]
Old 11-15-2009, 10:35 PM
Rep:3277
You need a soldering iron to heat the solder up from the adhesive slide then the wires into the soft solder, let cool and VOILA! or, you can try like my first attempt and burn through the gel coating down to the solder pad then try and get the wire to solder with outside rosin core. I recommend the first option.
I've got a 1" strip mounted under my hood so I can have nighttime lighting under there.
Kurtis
