Old 10-24-2009, 06:34 PM
allenw88's Avatar
allenw88 allenw88 is offline
Vehicle: 2005 Ram 1500 5.7 Hemi
Rep:22
allenw88 is on a distinguished road
Default Changing Headlights
Do I need to remove the entire headlight assembly or is there a way that I can change them out with out removal. If I do need to remove, can someone point me into the direction to see exactly how to remove. Thanks
Old 10-24-2009, 07:14 PM
98sst's Avatar
98sst 98sst is offline
Vehicle: 1998 Dodge ram 1500
Trim Level: SS/T
Rep:883
are you just changing the bulbs? or are you adding a HID kit, or a new assembly?
Old 10-24-2009, 07:16 PM
allenw88's Avatar
Rep:22
Just changing the bulbs
Old 10-24-2009, 11:38 PM
I push the skinny pedal
Rep:3277
If you're just changing the bulb then you don't have to remove the assembly, though it could make it easier for getting to the passenger side as it's kinda tight. To pull the bulb out, there's a housing that just needs to be pushed in then turned and it'll come out, then pull the red tab out and pull the bulb.
To pull the whole housing if you want, there's two torx bolts in the front behind the grille, as well as a nut behind a rubber plug in the wheel well. After those have been removed, there's a plastic clip that holds the housing in, to remove the assembly, take a flat blade screwdriver, wrap it in a rag and pry the top corner out, the assembly should just pop right out. Removing the assembly will make it easier to turn the bulbs in and re-installing them.
Kurtis
Old 11-05-2009, 02:19 PM
TRX4x4Wes's Avatar
TRX4x4Wes TRX4x4Wes is offline
Vehicle: 2009 Dodge Ram 1500 4x4 TRX
Trim Level: Trx
Color: White w/ silver bottom
TRX4x4Wes is on a distinguished road
what about changing an 09 bulb
Old 11-05-2009, 09:30 PM
glfd 40 glfd 40 is offline
Vehicle: 2009 crew cab
Trim Level: trx4
glfd 40 is on a distinguished road
Just changed to hid today. First, remove four 10mm screws that hold grille in place at top of grille. carefully lift up and unclip plastic baffle retaining clips to get better access to 2 middle screws. After 4 screws are out carefully pull out grill from right and left lower corners. Two spring clips hold grille on bottom. Next remove 2 screws that hold headlight lens assembly in place. Then open a small panel in forward wheelwell from the tire side. A white plastic tab must be lifted to release headlight assy. (on back of headlight). This info is to change bulb only,more required to go to hid set up ,drilling 1" hole to back of cap that covers h11 bulb and wiring up harness etc.....
Old 11-13-2009, 09:13 PM
Ramrob Ramrob is offline
Vehicle: 1999 Dodge Ram 1500 5.9L
Rep:75
Ramrob will become famous soon enough
on the 02-06 just the bulbs, passenger side is easy and the driver side you need to remove the housing.
