Old 04-29-2009, 09:23 PM
nlh8584's Avatar
nlh8584 nlh8584 is offline
Vehicle: 1997 dodge ram 1500 2wd auto
Color: red
nlh8584 is on a distinguished road
Default will these wheels fit?
I am assuming that these will work but just want to make sure before i go in with the deal. i want to purchase a set of stock dodge 20'' wheels and they are the 5 lug and i have a 97 1500 2wd 5 lug and i just want to make sure that dodge hasnt changed the 5.5 pattern
Old 05-17-2009, 02:20 PM
euromade euromade is offline
Gender: Not Specified
Vehicle: 2011 Quad Cab 4.7
euromade is on a distinguished road
what about the offset?
Old 05-17-2009, 03:49 PM
Here's some wheel specs to read that may help you determine fitment.
1994-1999 1500 2WD/4WD Aluminum Wheels
• Lug Pattern - 5 on 5.5", 1/2" bolt
• Rim Size - 16x7.0"
• Offset - +13.97mm
• Backspace - 5"
• Max Tire Size -
• 15x8.0 rims with 3.5" backspace will fit, but they stick out of the wheel wells.
Torque Spec
• 80-110 ft lbs (108-150 Nm) on 5 stud wheels
2000-2003 1500 2WD/4WD 17" Steel Wheels (Chrome or painted)
• Lug Pattern: 5 on 5 1/2
• Rim Size: 17x7"
• Fits 94 and up 1500 trucks
2000-2003 1500 2WD/4WD 17" Aluminum Wheels:
• Weight: 23.5 pounds
• Rim Size: 17x8"
• Actual width edge to edge: 9 1/16"
• Backspacing: 5 9/16".
• The space from the outside edge to the mounting surface (against the rotor) is 3 1/2".
• offset calculate: 1 1/32"
