Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 07-03-2014, 12:37 AM
rdstonerock rdstonerock is offline
Vehicle: 2001 Dodge Ram 1500 4x4
Color: Blue
rdstonerock is on a distinguished road
Default air volume
Air volume from AC decresses when I depress the gas pedal. Could this be a vacuum problem to the actuator/blending door?
Old 07-05-2014, 12:48 AM
Lazarus Truck Lazarus Truck is online now
Vehicle: 1997 Dodge Ram
Rep:194
Lazarus Truck has a spectacular aura aboutLazarus Truck has a spectacular aura about
Don't worry about it. It is designed so that "low-vacuum" will send the diverters to the "defrost" position. That way, if the vacuum fails, you will be able to see. Heavy pedal causes low vacuum also. It will divert to there under acceleration, but revert once vacuum is stable.
The difference between genius and stupidity, is that genius has it's limits. A. Einstein
