Old 06-29-2014, 01:41 PM
JPUSMC10x100 JPUSMC10x100 is offline
Vehicle: 2012 Dodge Ram Big Horn 4x4
Color: Grey
JPUSMC10x100 is on a distinguished road
Angry Huge loss of low end torque
This may have been covered and if it has I apologize.
I replaced my factory muffler with a Flow Master series 40, removed the resonators and added a K&N CAI on my '12 1500 5.7 Hemi but lost my low-end torque. The truck runs like a raped ape after about the 3000 RPM mark and I had significant gains on my mid and upper ends....but getting there from a stand still is a miserable experience.
Did I take away too much back pressure? I have never seen a truck be such a dog off the line then press you back into your seat seconds later when the RPMs catch up.
Anyone have a clue on what's going on with this thing and will a tuner fix this?
Thanks in advance guys.
Old 06-29-2014, 06:01 PM
chefred112's Avatar
chefred112 chefred112 is online now
Vehicle: 2005 Dodge Ram
Rep:656
did you reset pcm after install? if not, over time the pcm will learn new flow characteristics and adjust the tables and it will almost surprise you when it does wake up..
Old 06-29-2014, 09:40 PM
Color: Grey
Will it reset by simply taking off the battery terminals and letting it set for a minute or two?
Old 06-29-2014, 10:47 PM
chefred112's Avatar
Rep:656
i've heard that...in the 3rd genners we just pulled fuse 23 and held the key to start position for 30 sec or so...then drive it hard for a short while so that pcm learns your driving characteristics and adapts
Old 07-10-2014, 10:58 AM
Jbenson Jbenson is offline
Vehicle: 2014 Ram 1500
Trim Level: Big horn
Jbenson is on a distinguished road
Did you figure anything out or did your truck ever wake up. I just did the same thing and noticed a big power loss when I take off from a stop.
2014 Big Horn 4X4. Vararam, Diablo tuner, 40 series flowmaster, 3.92 gears, retro shop 5k HID's
Old 07-14-2014, 10:11 PM
Hear-Me's Avatar
Hear-Me Hear-Me is offline
Vehicle: 2006 Dodge Ram
Color: Atlantic Blue Pearl Coat
Hear-Me is on a distinguished road
Angry Me tooo
Okay I just installed my Banks monster exhaust and low end torque is much less????
Can anyone please help us out in this thread?
2006 Ram 1500 Laramie,5.7 HEMI,4x4,Build Date 4/28/2006, K&N filter,Snugtop SL, Bank's Exhaust
Old 07-14-2014, 10:44 PM
jharrram13's Avatar
jharrram13 jharrram13 is offline
Vehicle: 2013 dodge ram
Trim Level: express
Rep:25
jharrram13 is on a distinguished road
Probably not what you want to hear but you could put in a stall converter and that sucker would really scream if you just flash all the way up to 3000rpm
Old 07-14-2014, 11:13 PM
Hear-Me's Avatar
I've left 3 emails today...because they were closed by the time I got home. I am not happy...it was stronger with the stock exhaust!!!!
I'm hoping they have a fix for me tomorrow..................this sucks. What a buzzzz kill.
Old 07-30-2014, 07:16 AM
Color: Grey
Resetting the PCM did help out but it doesnt take long for it to slowly go back to its norm. Im thinking the only solution that is viable right now for my finacial position is replace that series 40 muffler with something a little more restrictive and then install a tuner.
I have read that fuse #19 on the 05's disconnected the traction control.....can anyone advise on which fuse disconnects it on the 12's??
Old 07-30-2014, 09:59 AM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
I have read where several people have experienced a loss in low end power with Flowmasters in particular. I had a similar experience with a FM on my last Ram. Couple of thoughts on the matter.....
For one, I have often wondered if at least some of our "perceived" loss of power is actually just due to us being able to hear what the engine is doing much better with an aftermarket exhaust. Does being able to hear the engine working so much better make us think the engine is working harder to do the same thing it did before?
Also, from what I have seen, the general theory seems to be that swapping mufflers lessens backpressure and this is what causes the loss of low end. Makes sense as I wouldn't think there is any chance that a FM is more restrictive than the stock exhaust. However, from what I have seen, owners switching to Magnaflow systems are much less likely to experience the perceived loss. And if you search, there are threads showing that in general MF mufflers make better power numbers than FM. Yet MF is a straight through design rather than chambered like FM and is supposed to be a very high flow muffler. One would think a MF would create even less backpressure.
Just food for thought.
