Old 06-25-2014, 06:38 PM
Mdsh004 Mdsh004 is offline
Vehicle: 2005 Dodge Ram 1500 SLT 4x4
Trim Level: SLT 4x4
Color: Bright Met Silver
Mdsh004 is on a distinguished road
Default Hey guys/gals
Looking for aftermarket exhaust on 05' Dodge Ram 1500 with 5.7 Hemi...
Had someone tell me the hemi's loose bottom end torque with true duels ? I was thinking about replacing the cats with high flow and x-pipe to duel to 2 chambered mufflers and then out the back ? Someone from muffler shop I looked at said the Hemi looses bottom end torque...? Do they with this set up..?
Old 06-26-2014, 09:10 AM
Kamanhart's Avatar
Kamanhart Kamanhart is offline
Man Up And Cam Up
Rep:1045
Kamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud of
It relies on your mods and the pipe they use, if you are basically stock then running 2.5" pipe all the way out with a cross over and chambered mufflers should not hurt your bottom end, if you have cam, head work and headers then you can bump that to 3" all the way out and still be alight it just depends on what you have done.
Old 06-29-2014, 01:36 PM
chefred112's Avatar
Rep:656
...I agree with kamanhart.... Initially you may feel the loss at the beginning but when the pcm learns the new flow characteristics, it more than makes up for the lost feel...take it from a fellow 05 hemi owner
5.7 e.t.'s: 1/8 - 7.85@93.20, 1/4 - 12.10@113.96 juice - 12.96 NA... 6.4 e.t. 12.59@106 NA
Old 06-29-2014, 01:41 PM
chefred112's Avatar
Rep:656
...this will also help as you mod up, when you add a cai and a programmer as well as the deeper mods...
