Old 05-22-2014, 05:07 PM
Danstona Danstona is offline
Vehicle: 2005 Dodge Ram 1500 4x4 5.7L
Trim Level: Hemi Sport
Rep:35
Danstona is on a distinguished road
Default Front End suspension on 05 any poly bushings?
As the topic says.. Is there anyone selling poly bushings for the end links and sway bar and control arms?
Old 05-22-2014, 06:23 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:427
hydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nice
BWoody has excellent sway bar end links with poly bushings. You might check Energy Suspension, they may have poly bushings for our Rams, don't know. As far as sway bar bushings, if you drill and tap for zerks and drill clearance hole for the grease thru the bushings, the factory ones last pretty well if you grease with silicone grease at every oil change. I run all poly bushings on my Dodge Magnum, not sure that I'd want them on the Ram. My Ram rides better than the Magnum!
Inertia Spartan Plus cam, Circle D 3,000 rpm stall converter,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's,3:92's, extra rear leaf.Line-X Bedliner,GY Armortracs, 210,000 miles To Hell and back. 14.2/96 mph NEDW
