United Radio
Old 05-15-2014, 09:35 PM
powerram1500 powerram1500 is offline
Vehicle: 2005 dodge ram 1500 slt
Color: silver
powerram1500 is on a distinguished road
Default 2005 Ram 1500 4x4 torsion key lift?
Hey everyone, I have a 2005 Dodge ram 1500 4x4. I was thinking of getting a 2" torsion key leveling kit installed since my truck doesn't have front coil springs. I've heard a lot about them ruining CV joints and what not... Anyone have some good advice? I would like to level my truck without getting a lift, not a huge fan of lifts.
Thanks.
Old 05-16-2014, 12:56 PM
Wandell's Avatar
Wandell Wandell is offline
Rep:35
Just crank up your torsion bars using the stock keys. The aftermarket keys will allow you to put way, way too much preload on the torsion bars. This will result in a stiff ride, extreme CV and ball joint angles and increased wear. Just crank up your torsion bars enough to level the truck and get an alignment. No need to buy a product that lets you do something you can already do.
Old 05-16-2014, 03:29 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:1969
brandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant future
Exactly what Wandell said ^^ Torsion keys are a waste of money.
8" BDS Long Arm Lift with Fox 2.0 Shocks | Dual Fox 2.0 Steering Stabilizer | 37x13.5 Toyo MT's | AMP Powersteps & Bedstep | Bakflip G2 | Mag-Hytec Rear Diff Cover
EST 500 hp/1268 ft-lbs at FW | H&S MiniMaxx Custom Tuned | 4" Flo Pro Stainless TBE | Sinister EGR Delete | ARP 425 Head Studs | 4.56 AAM/Yukon Gears | S&B Intake w/ Scoop
Old 05-16-2014, 03:48 PM
Color: silver
how much of a level is safe without messing things up? 2" and under?
Old 05-16-2014, 04:12 PM
Rep:1969
2" is definitely safe. On most trucks you can go 2.5" no problem. Take measurements of your 4 fender heights to determine how much rake you have. You'll want to retain at least 0.5" of rake to avoid looking nose high. Then you can figure out exactly how much you need to lift the front end to be level.
Old 05-19-2014, 12:26 PM
Wandell's Avatar
Rep:35
And keep an eye on your ball joints and cv joints. Just make sure the angles don't look too severe.
4x4, leveling kit, torsion bar keys
