Old 05-09-2014, 06:11 AM
masonsnow masonsnow is offline
Vehicle: 1999 ram 1500
Color: blue
masonsnow is on a distinguished road
Default 5.2 to 5.9 swap
hi I have a 99 dodge ram 1500 slt Laramie it is a 4x4 with a 5.2 magnum has the tranny cooler and tow package I really like this truck but want a bit more bang in both hp and torque I debateing on doing a swap but ive done one before but on my chevy lol it was a night mare I was wondering if anyone out there has accomplished this task and if soo give me some insight and a run down and as much info as possible and also peoples takes on is it worth the work or is there some magical way to make this 318 come to life please some one help
Old 05-10-2014, 09:32 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:427
hydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nice
You have an electronic fuel injected motor. Anything that you do to get more power may need to modify the tune to get it to run right. I've seen some monster, procharged 408 strokers built and successfully tuned that ran like bats outta hell. I think SCT makes a tuner that will work on your motor. Not sure how far you can go without tuning. With the hemis, you can do a few things, but even a cam can cause problems.
Inertia Spartan Plus cam, Circle D 3,000 rpm stall converter,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's,3:92's, extra rear leaf.Line-X Bedliner,GY Armortracs, 210,000 miles To Hell and back. 14.2/96 mph NEDW
Old 05-11-2014, 07:36 PM
Joeinblue Joeinblue is offline
Vehicle: 1994 Ram 1500
Rep:15
Joeinblue is on a distinguished road
Keep in mind that unless Chrysler made changes with the introduction of the Magnum engines, the 360 (5.9) is externally balanced, where the 318 is not. I found this out the hard way back in the early 1990s. I broke the crank in my 360, but had a running 318 that was ready to swap in. Everything bolted up, including the flywheel for my 4 speed in the Power Wagon. When I started the engine and reved it a little, I noticed the engine had a nasty vibration. I needed a 318 flywheel without the external balance. It was a lot of work for nothing.
I mention this because I have the 5.9 out of my 1994/1957 project and noticed there is a pretty good sized balance weight welded to my torque converter, and the flexplate is indexed to correspond with that weight. The 1994 flex plate does not have a balance weight on it, but the 1999 flex plate that came with my new motor does.
As long as you have the right parts, it will work.
-Joe
1500, 1999dodge ram, ram
