Old 04-29-2014, 10:31 AM
dvc357's Avatar
dvc357 dvc357 is offline
Vehicle: 2014 Ram 1500 ST Express QC
Trim Level: ST Express Black Out
Color: BLACK
dvc357 is on a distinguished road
Default Custom Exhaust Sungle Vs True duals
Ok,
So im old school. I have my new 2014 Ram Express ST Quad with a 5.7.
Should i NOT go to a true DUAL exhaust? some have reported the the Two to One actually performs better?!!?
Ive never heard of this before.
Input?
Old 04-29-2014, 11:30 AM
Scrum Scrum is offline
Vehicle: 2014 Dodge Ram Sport
Color: Granite
Scrum is on a distinguished road
I have no answer but that is a question I have asked myself before..How hard would it be to make it a true dual exhaust and what would be needed to do it.
Old 05-01-2014, 12:56 PM
cvieke's Avatar
cvieke cvieke is offline
Vehicle: 2008 Ram
Trim Level: TRX
cvieke is on a distinguished road
Don't know if it is true or not, but have been told on true duels you loose some low end torque, but gain it on the higher RPMs, something about less back pressure on the low end.
Volant CAI, Magnaflow muffler, 2" leveling, 3" body lift, Bushwacker fender flares, 4.56 gears
Old 05-06-2014, 12:09 AM
JRob JRob is offline
Vehicle: 2010 Dodge Ram Big Horn
JRob is on a distinguished road
There are so many options to choose for duel exhaust, it's a matter of what you want to pay. Your factory exhaust funnels into one converter, then back out to two mufflers. The most affordable swap, and the easiest is to change out parts after the converter...remember the stock exhaust was meant to pass emission tests, not necessarily for mpg or hp. Flow Master and companies like Magna Flow offer good systems that are less restrictive than your stock unit, thus increasing hp and giving you a more aggressive sound. All newer vehicles are required to have a converter, so if you want more performance you can go with true duel exhaust, starting at the exhaust manifold. For the most performance you want to go with headers, two separate converters, an x-pipe to even the pressure out, and then two mufflers. Replacing all those parts gets expensive, parts alone in the $1000's and then include labor.. That's why you see the converter back systems, more affordable and still good hp gains.
Old 05-06-2014, 01:12 AM
Brandon Snyder's Avatar
Brandon Snyder Brandon Snyder is offline
Vehicle: 2007 Dodge ram 1500 Hemi
Color: flame red
Rep:13
Brandon Snyder is on a distinguished road
I have true dual flowmasters with an X pipe right now and I have got to say I love the soundI could feel a good bit of an increase in higher RPM's a little bit of increase in low end torque I did have a single and do out before the true duals and also liked it but what really comes down to is how much you want to pay anythings better than stock I would have to say like thati like the true duals better. I only paid a total of 750 for tailpipes mufflers x pipe and labor
True dual flowmasters, 2 12 in Memphis, kicker door speakers, Kenwood head unit , 2.5 ready lift level, 33in mts, fuel hostages 17, Afe cai, bbk 85mm throttle body, weathertech floor mats, Aries bull bar , 2 kc off-road lights, superchips 3865.
Old 05-08-2014, 06:48 PM
gixxer160's Avatar
gixxer160 gixxer160 is offline
Vehicle: 2013 ram 1500 laramie
Trim Level: Leather
Rep:7
gixxer160 is an unknown quantity at this point
An X pipe only reduces noise and flow. My system will be a true dual, no X pipe or H pipe. You do NOT need an X or H pipe. just run straight back for best performance and sound. I will find out next week and confirm.
Old 05-08-2014, 10:59 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
There's a lot of misguided information on the internet (and from many people). Back pressure is always bad. Technically a true dual exhaust (sized appropriately) with a crossover(x or h pipe) will perform the best. BUT, a dual to single (y pip setup) sized appropriately performs almost just as good, is significantly cheaper, easier to install, and lighter. I'm of the opinion that the 1 or 2 hp you MIGHT gain on the perfect dual setup is offset by the extra 5-10lb of the duals.
Crossovers are crucial to the good performance. It helps with scavenging.
Scavenging and velocity(sizing of pipe diameter) are what's most important overall. The best bang/buck is definitely a dual to single setup. For most of these 3rd/4th gen v8 rams optimum is dual 2.5" pipes to a 3" single.
Hope this helps.
Sean
Old 05-09-2014, 12:25 AM
BlackRamHemi's Avatar
BlackRamHemi BlackRamHemi is online now
Vehicle: 2010 Ram RCSB 4x4
Rep:554
100% Wrong!
Hope this helps.
100% Correct!
Old 05-18-2014, 11:07 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
I also agree, an X or H is needed for scavenging and balancing exhaust pulses.. us guys that do alot of track time can't ALL be wrong about this..
5.7 e.t.'s: 1/8 - 7.85@93.20, 1/4 - 12.10@113.96 juice - 12.96 NA... 6.4 e.t. 12.59@106 NA
Old 05-28-2014, 08:39 PM
gixxer160's Avatar
Trim Level: Leather
Rep:7
Yesterday I had my exhaust changed to a true dual system using a pair of AT2525 Aero Turbine mufflers. No X pipe or H pipe. The sound is amazing and the performance is great too. Smooth power all the way through. So far no problems. Very Happy. I will get pics up soon.
