Old 04-16-2014, 01:50 PM
BlkXpress25's Avatar
BlkXpress25 BlkXpress25 is offline
Vehicle: 2013 Ram Black Express
Rep:28
BlkXpress25 is on a distinguished road
Default Tinted fog lights- 2013 Express
In case anyone was wanting to do the same....I found the Lamin-x wasn't the right size/ difficult to line up correctly.
35% tint from O'Reilly's- 8.99
Before:
During:
After:
Old 04-16-2014, 06:25 PM
Campbell402's Avatar
Campbell402 Campbell402 is offline
Vehicle: 2014 Ram 1500
Rep:73
Campbell402 will become famous soon enough
That looks really good. I was going to order lamin x for the fogs last week glad I waited. How hard was it to remove the bumper cover? I've hard the grill and lights apart a few times, but have never taken off the lower bumper cover.
Old 04-16-2014, 10:43 PM
JOE760's Avatar
JOE760 JOE760 is offline
Vehicle: 2014 Ram R/T
Trim Level: R/T
JOE760 is on a distinguished road
looks good
- Vararam Air Grabber, -Aero Turbine 3030 muffler w/ Resonators deleted, -Retroshop 6000k HID low beam kit
Old 04-17-2014, 10:23 AM
Rep:28
Thanks all
The bumper is fairly easy to remove. After removing the grill and lights here is what I did-
1) Remove bolts/clips for fender liner- bottom 4 on each side. The bottom 3 attach the actual bumper, but removing the 4th allows you better access to the two bolts on each side that hold the bumper behind the lights (explained better in next step
2) Behind where the lights sit there are four bolts total - 2 on the passenger side, 2 on the driver side. I believe they are 10mm bolts, so the same socket used for the headlights and grill work here as well. Remove these two from each side.
3) Underneath the truck, where the valence meets the bumper there are 4 bolts that need to be removed, also 10 mm
4) All bolts are gone at this point, I found it easier to start with one corner of the bumper and pull lightly to release the clips, and once that corner is gone go to the other. Be careful when pulling the second side, as once the clips on each side are off it will pretty much fall forward on it's own.
I didn't look up directions so it took me a little longer figuring where everything was out... but to put it on took about 10 minutes, I imagine it would be about the same to take it off.
Also, I didn't use power tools, just hand tools. So those would help too.
Old 04-17-2014, 09:13 PM
Rep:73
Seems easy enough, thank you for the info!
Old 04-21-2014, 10:59 PM
Chunkem's Avatar
Chunkem Chunkem is offline
"Just living the dream"
Trim Level: Longhorn Rambox
Rep:1637
Looks sweet.....Nicely done.....
Old 05-05-2014, 06:09 PM
BowHunter11's Avatar
BowHunter11 BowHunter11 is offline
Vehicle: 2004 Dodge Ram 2500
Engine: 2004-2004 359ci (5.9L) Cummins ISB 600 24-Valve Diesel I6 325hp 600lb/ft
Rep:63
BowHunter11 will become famous soon enough
Looks good. How much did the light output change?
Rough Country - Rancho - Nfab - 305/55 Dick Cepek Fun Country - 20x10 XD Diesel - Smarty - K&N - Air Dog - 4" Straight Pipe to 6" Tip - Turbo Silencer Ring MIA - Husky Liners - Kenwood - Spyder Lights - 30" Curved LED - Truxedo - Bushwacker Pocket Flares
Old 05-06-2014, 10:38 AM
Rep:28
Pic with the garage was about 7 or 8 feet away from the garage
Old 06-08-2014, 03:42 AM
USAF Long's Avatar
USAF Long USAF Long is offline
Vehicle: 2013 Ram 1500 RCSB
Rep:69
USAF Long will become famous soon enough
Send a message via AIM to USAF Long
I just put the yellow lamin-x light covers on my fogs tonight, they are too small so the light is yellow but if you look at the truck you can see white light around the edges. I might take the bumper off and buy some yellow tint and do it myself, or maybe I'll just order a 2500k HID kit for the fogs.
-Scott Long-
2013 Ram Express RCSB: 5% tint, de-badged doors, muffler delete y-pipe, K&N panel filter.
Best Run: 14.60@96mph with 2.4 60' at Kil-Kare Raceway in Ohio
Old 06-09-2014, 02:45 PM
Rep:28
Yeah, that's why I went the tint route. The lamin-x wasn't the right size.
