Old 04-12-2014, 02:22 AM
BC18471's Avatar
BC18471 BC18471 is offline
Vehicle: 2011 Dodge Ram
Color: Gray
Rep:31
BC18471 is on a distinguished road
Default Retrofit 2011 Fogs and Headlights
Here is a sneak peak at my current project. I got spyders, then to my dismay, found out that they are not that good. So before even putting them in my truck, I ripped them apart and started upgrading.
I am adding TRS XB halos to replace the CCFL's as the CCFL's are not nearly as bright. I also purchased the retroquick kit which will be going in soon.
Now the fogs were a different animal. As you probably know, you have to cut the housing in order for the projectors to fit.
Now, I had help from someone, and what he did was cut a rigid cup and set it up so the projector threads though that and sits against the back of the housing...
What this does is allow movement of the projector so I can align it. When I get the projector where I want it I can tighten the thread on the cup and then put some beads of JB Weld to hold it. Then I can remove the cup and give it a foll dose of JB weld to seal and hold it securely.
I will try to get more pics up as I progress. I am hoping to have the fogs done this weekend, but I am still waiting on the halos for the headlights.
Custom Katzkin leather, Magnaflow 14" with Y, Mopar CAI, Moroso Catch Can, 180* t-stat, Switchback Front turn signals, All LED lighting, Kenwood DNX6180, Cabin air filter, Smoked Tails and 3rd, Audiovox backup camera
Old 04-12-2014, 02:34 AM
RogerRamJet's Avatar
God Bless Texas!
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
So far so good! I got Spyder heads as well and was impressed right up to the point when I actually turned them on and hit the road. Luckily, I put HID's in my fogs, so they make up for the lack of output from the heads.
Keep up the good work!
Old 04-12-2014, 09:42 AM
jramlvr jramlvr is offline
Vehicle: 4th Gen Ram
jramlvr is on a distinguished road
if i'm seeing the picture correctly......the fog projector is upside down.
neat idea on the cup there too!
2010 Ram 1500 Crew
Old 04-13-2014, 12:48 AM
BC18471's Avatar
Color: Gray
Rep:31
Thank you! I had to pull them out of the fogs to put the shrouds on only to find out I have to cut the shrouds to get them to fit. This has been quite a learning experience, but fun being able to put my own spin on all the lighting. I am also having a problem having the MH1's seat in the headlights without having some movement...
Old 04-13-2014, 08:40 AM
what shrouds in the fogs? Mini gats fit with no trimming.......
I haven't messed with the MH1 / spyder plate yet - that should be pretty straight forward though, as the plate mounts between the bowl and lens, then uses the spyder mounts?
2010 Ram 1500 Crew
Old 04-14-2014, 12:00 AM
BC18471's Avatar
Color: Gray
Rep:31
Yes, I haven't had a chance to check the rotation, but obviously this the retroquick kit allows fir up and down adjustment. It was a very snug fit so I am hoping that the rotation is spot on.
I just verified that I did get the mini gats, but they are hitting the top of the fog housing. I am going to have to notch the top of the shroud to get it to fit, but it will fill up th housing perfectly.
fogs, hid, projector
