Old 08-22-2014, 01:32 PM
ROKNK5 ROKNK5 is offline
ROKNK5 is on a distinguished road
Default 2000 Ram - Lost FM Stations
2000 Ram, 135K miles, factory radio (CD & cassette tape). I've lost all FM stations, all I get is static. Oddly, I can pick up AM stations. Antenna on exterior of truck is tight. Any ideas?
Thanks,
DC
Old 08-22-2014, 08:47 PM
logang logang is offline
Vehicle: 2003 Dodge Ram 1500
Color: Dark Garnet Red Pearlcoat
logang is on a distinguished road
Try checking the antenna cable going into the rear of the radio. Follow the antenna cable as best as you can to where it joins the antenna behind the wheel well cover under the antenna, it may have become disconnected somehow.
Old 08-24-2014, 12:09 AM
Lazarus Truck Lazarus Truck is offline
Vehicle: 1997 Dodge Ram
Rep:194
Lazarus Truck has a spectacular aura aboutLazarus Truck has a spectacular aura about
I just had my right fender off for some work. There was CRAZY corrosion where the antenna cable went into the antenna base. Couldn't get them apart. If you can find a test antenna and cable, there is a splice connector under the passenger side of the dash, right above your feet for the antenna. Plug in a known good antenna, and that should help locate your problem.
The difference between genius and stupidity, is that genius has it's limits. A. Einstein
