United Radio
Old 04-03-2014, 10:17 PM
jdip jdip is offline
Trim Level: Outdoorsman
Color: Deep Cherry Red Crystal Pearl(Its effin Dark Red)
Rep:26
jdip is on a distinguished road
Default HELP! load resistor on led 3rd brake light
Just installed my recon 3rd brake light. Aside from me having to figure out how to tighten up the light since it doesn't look well sealed ...I'll handle that later
I'm having the notorious cargo lights staying on and dim when not in use. I know this is a commom problem for recon 3rd brake lights. They will stay dim when the truck is on and will eventually go away when the battery drains when its off.
I've purchased a 8ohm 20 watt resistor and a 6ohm 25 watt resistor set. How do I go about installing this. As I said the cargo light is only affected at this point. Thanks!!!
Old 04-03-2014, 10:29 PM
Canadian Hemi Pride's Avatar
Stickers add Horsepower
Vehicle: 2008 Dodge Ram 1500
Trim Level: SXT 4x4
Color: Silver/ Black
Rep:2793
If the resistors have wires coming off of them, you should just be able to splice them into the power and ground wires. If they are solid metal ends, you will probably need to soder them in.
Tow mirrors up for the haters
Old 04-04-2014, 01:19 AM
Rep:26
Thanks! All seems well much later then I wanted it to be though. Ended up using the 6omh 25watt and tapped the white wire which is the cargo light on the light side and its white tan stripe on truck side. Tapped the ground black wire for the other side. Problem solved. Wrapped it in electrical tape and 3m lok taped it above the light inside the lip of the cavity. I assume this entire problem stems from the current load resistor being for the brake light only?
As for mounting still concerned about the potential water problem. I know this as well has been a notorious problem. But I got #10 1 1/2" screws (light is OEM mounted with #10 1 3/4") and ran some black silicone around the edge. After 24 hours assuming it doesn't rain and I find out the hard way I'll give it a water test and report back
Old 04-06-2014, 09:42 PM
moparornocar72's Avatar
Rep:630
happened on mine also. Just figure out which wire powers the cargo light and put a resistor between it and the ground. Fixed mine permanently!
14.268 @ 95 MPH Full Trim
Old 04-12-2014, 07:07 AM
Rep:26
Thanks everyone. Week 2 doesn't look like I'm leaking nor have I had any further problems.
Old 04-15-2014, 01:50 AM
BlownGP's Avatar
BlownGP BlownGP is offline
Vehicle: 2009 RAM CC Sport
Color: Sunburst Orange Pearl
Rep:15
BlownGP is on a distinguished road
I put LEDs in my stock 3rd brake light. The cargo lights do stay longer and dim then normal, but it's never caused me any problems. They eventually go off.
98 GTP-Mods? Yeah, lots of them
2009 Ram CC Sport- Mods very SOON!!!
