Old 03-23-2014, 03:45 PM
spnich1x's Avatar
spnich1x spnich1x is offline
Vehicle: 2011 1500 SLT Quad Cab
spnich1x is on a distinguished road
Default Under Dash LED
Hello all, I am new to the forum and grateful for your help. I am looking to install LED lighting but using the dinner switch to tap into. I have seen posts to tap into the 12v cig outlet, but none on the dimmer switch.
Anyone tried that? Tips to route or things to avoid?
Thank you.
Old 03-24-2014, 07:27 PM
Jhouse's Avatar
Jhouse Jhouse is offline
Vehicle: 2014 ram
Color: blue streak pearl
Rep:163
Jhouse has a spectacular aura aboutJhouse has a spectacular aura about
Are you trying to get a constant hot or with the headlights on hot
K&n cai, bt catch can,moes 87mm throttle body,flowmaster super 44,20% tint front 15% rear,egr vent guards, black weatherguard toolbox, debadged,tinted tails,retroshop hid's 6000k in fogs and lows, custom mopar badges
Old 03-25-2014, 10:07 PM
Guls Guls is offline
Vehicle: 2014 Dodge Ram Bighorn
Trim Level: Bighorn
Rep:14
Guls is on a distinguished road
Connect it to the headlight switch.
Old 03-27-2014, 01:46 PM
spnich1x's Avatar
Just want on with the head lights, but I would like to have be dimmable like the dash lights.
Sorry for my slow reply. Thank you for the feedback.
Old 03-27-2014, 01:51 PM
Iqudayo's Avatar
Iqudayo Iqudayo is offline
Color: Mineral Gray Metallic
Rep:563
hmm interesting
Old 03-27-2014, 07:13 PM
Trim Level: Bighorn
Rep:14
Tap into the wire that illuminates headlight switch, it is dimmable. I will be doing this mod once it gets little warmer.
Old 03-30-2014, 10:57 PM
spnich1x's Avatar
Thumbs up
Thanks I will give that a try.
Old 05-25-2014, 01:53 AM
spnich1x's Avatar
So I finally got it done and the advice paid off. Thank you. Looks great and dims with the dash lights. perfect.
Thank you
Old 05-25-2014, 07:42 AM
Trim Level: Bighorn
Rep:14
Post some pics and which wire did you tap into.
Old 05-26-2014, 01:11 AM
spnich1x's Avatar
Thumbs up Pics and how
Here are the pics. I used the wires coming off the headlight selector switch. I used the org/gry and the blk/tan (Pic of wire diagram below)
This did allowed me to dim them with the dash lights, though these are fairly bright so the effect is not as much as I hoped.
I was not sure where to mount the lights so I punted expecting to have to tweak them later. I got the lights from Autozone for like 12 bucks. I mounted 1 strip on the panel that is under the steering column. Funny it also shines blue light up through the cover around the steering wheel (Not sure I like that.) The other strip I mounted under the glove box. There is a bar that supports the box and is well suited for that. I fished the wires under the center panel and tied them to the first string.
Please do not judge the wire management, it is temp till I decide the placement is right. I am not that happy with the driver side placement so if anyone has a better location please fill me in.
My first attempt at this type of work so I am sure there are better ways to do this.
Thanks for the help and support.
dash, led, lights
