Old 03-23-2014, 12:25 AM
Brandon Snyder's Avatar
Brandon Snyder Brandon Snyder is offline
Vehicle: 2007 Dodge ram 1500 Hemi
Color: flame red
Rep:13
Brandon Snyder is on a distinguished road
Default wheel spacers
i got a Really good deal on some 35 in mud grapplers and I know I need some wheel spacers. My buddie has some hubcentric .5 in wheel spacers. Will I be okay to run them untill I get new rims I Will only run them for about 1000 miles or so. I also have a 2.5in level.
True dual flowmasters, 2 12 in Memphis, kicker door speakers, Kenwood head unit , 2.5 ready lift level, 33in mts, fuel hostages 17, Afe cai, bbk 85mm throttle body, weathertech floor mats, Aries bull bar , 2 kc off-road lights, superchips 3865.
Old 03-23-2014, 01:25 AM
LowUFO's Avatar
LowUFO LowUFO is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Sport Crew
Color: True Blue Pearl
Rep:1105
Yeah. Just check the lugnuts are tight every few days at first. And don't be surprised if you get a bit of speed wobble around 60mph or so. You might get lucky and not have any vibration, or you might get it quite bad. It's a crapshoot. But as long as they are the correct bolt pattern for your truck, you can run em. I've run them on some high performance cars before and other than a slight vibration around the aforementioned speed, they were fine.
Maybe try without first and see if it only rubs at full lock. If so, you could just go without for that thousand miles/kilometers...
Simon
Old 03-23-2014, 02:15 AM
Color: flame red
Rep:13
Alright thanks
Old 03-29-2014, 05:09 PM
mb power wagon's Avatar
mb power wagon mb power wagon is offline
Vehicle: 2007 dodge power wagon
Trim Level: power wagon
Rep:68
mb power wagon will become famous soon enough
if you want to avoid the vibration the spacers can give put some industrial adhesive on the spacers and attach them to the wheels before you have them balanced with the new tires. i have done that before and it worked great. no vibration at all. the best way to make sure they are on properly is to put the wheels on the truck and put the wheel nuts on tight and leave them on for a few hours till the adhesive dries. than go get your new tires put on the rims and balanced and you shouldn't have any vibration.
Old 03-29-2014, 07:18 PM
Boosted's Avatar
Boosted Boosted is offline
Trim Level: Outdoorsman
Color: Black/Mineral Gray
Rep:219
I would not feel comfortable with running a .5 inch think wheel spacer as that is quite a bit of the threads that the lug nuts would not engage. I suggest checking that before running them.
Old 03-30-2014, 08:55 PM
LowUFO's Avatar
Rep:1105
The minimum requirement for a car on the track is six full turns of the lug nut. Lots of people running spacers with six or seven full turns of the lug nuts. I can't see it needing to be more than that on a non race vehicle. So as long as you have that, you'll be fine. If not, step up to an adapter with it's own studs that bolt right to the studs on the truck and the wheel sits on the new studs sticking out of the adapter.
Simon
Old 03-31-2014, 12:31 AM
Captain10's Avatar
Captain10 Captain10 is offline
Vehicle: 2007 Dodge Ram
Captain10 is on a distinguished road
Have you heard about the wobble at that speed with only a 1/4" spacer. I need to run them on my truck. 35s on the stock 20s and this is the first Ive heard about it in my limited research. Ill be running spacers for about a year until I can splurge for new rims.
35x12.5 Federal Couragia M/T|20x9 Ballistic Jester 0 offset|Bilstein 5100 Maxed|Magnaflow Muffler|ARE Tonneau Cover|LED Tailgate Light Bar
Old 03-31-2014, 12:43 AM
LowUFO's Avatar
Rep:1105
I have. But there are no guarantees. You may get lucky and have no issues. Hubcentric spacers are the best way to minimize the chance of vibrations around 60mph.
Simon
Old 03-31-2014, 01:43 AM
jrnannery jrnannery is offline
Vehicle: 2009 Ram QC SLT 4.7L 4x4
jrnannery is on a distinguished road
I was assured by a gentleman at the local truck accessories place that with a set of bilstein 5100's on the front that 35's on stock wheels would not rub.
Old 03-31-2014, 01:12 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
That would depend on how wide the tire is. You can fit up to 35" of height on the stock wheels no problem. But once you go wider than a 285 on stock wheels you're risking rubbing.
