Old 03-21-2014, 09:18 AM
jrnannery jrnannery is offline
Vehicle: 2009 Ram QC SLT 4.7L 4x4
jrnannery is on a distinguished road
Default Must I lift for 35s?
I have a stock height 09 SLT that I want to put 35s on, but I don't want to run into issues, like fenders. Do I have to lift it, or will they fit just fine?
Old 03-21-2014, 09:32 AM
theGSE10's Avatar
theGSE10 theGSE10 is offline
Vehicle: 2013 Ram 1500 4WD Crew Cab
Color: Maximum Steel
Rep:33
theGSE10 is on a distinguished road
I don't believe you can't fit them stock but you can fit them with a 2-3" level, which is much less complex than a lift. However for a 35x12.5 you will also want either a wheel with a negative offset or a 1/4" wheel spacer or they will rub. The issue is not with the height but with the width. A 12.5 or really anything over 295/65 will rub without the right offset or a spacer.
Hellwig Sway Bar, Green filter, Borla XR-1, Line-X, Bak RollX, JBA TCC Shorty's, Raptor 4" nerf, Hunter Bull Bar, 20" Cree LB, Moroso Catch Can, Bilsteins @ 2.8, Fox 2.0 rear, TGC 1.75 spacer, Air Lift 1000, Bak Box 2, Trinity T1000
Pics: https://www.dropbox.com/sh/ut4enlwx4fslgd8/slpdRXv6z2
Old 03-21-2014, 10:10 AM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
level it and get spacers or new wheels
Old 03-21-2014, 10:16 AM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
exactly this ^^^
Old 03-21-2014, 08:07 PM
Awesome guys, thanks.
Old 03-24-2014, 12:47 AM
usmcz28 usmcz28 is offline
Trim Level: 1500
Color: Blue
usmcz28 is on a distinguished road
Originally Posted by Bully's Performance View Post
exactly this ^^^
What size spacers?
Old 04-05-2014, 03:38 PM
I talked to a guy at the local 4x4 truck place. He says that even with the stock wheel offset, 35s should fit under the truck with no wheel spacer, and no rubbing...that would be 35-12.50R17s. I would use the Bilstein 5100s to get the front leveled.
Old 04-06-2014, 02:00 AM
LowUFO's Avatar
LowUFO LowUFO is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Sport Crew
Color: True Blue Pearl
Rep:1105
He doesn't know what he's talking about. The widest you can go without at least a quarter inch spacer behind the stock rim is 285. Anything wider than that, it's almost guaranteed you will have rubbing.
An aftermarket rim with a zero offset or so will get you clear.
Trust us on this. We see this question ten times a day.
Simon
Old 04-06-2014, 10:25 AM
Spaightlabs Spaightlabs is offline
Vehicle: 2014 Limited
Trim Level: Longhorn Limited
Spaightlabs is on a distinguished road
Yup. He's trying to sell you tires. Once you buy them and he goes to install he will give you the news - "looks like you are gonna need a leveling kit and spacers."
Old 04-06-2014, 11:45 AM
Canadian Hemi Pride's Avatar
stance makes her dance?
Vehicle: 2008 Dodge Ram 1500
Trim Level: SXT 4x4
Color: Silver/ Black
Rep:2802
Yeahhh.. You need offset to fit 12.50 wide tires. I have -12 Offset with 35/12.50/17 toyo open country m/t. They just fit in there when doing sharp turns. Stock rims, especially 17" would cause very bad rubbing.
This is how they force you into spacers, then get more money to charge you to remove tires, put it all back together and prob throw an allignment in or something. They could also try milking new rims to you.
Tow mirrors up for the haters
