Old 03-12-2014, 05:14 AM
bigdawg3362 bigdawg3362 is offline
Vehicle: 2009 Dodge Ram 1500
bigdawg3362 is on a distinguished road
Default Lift kit, Rims, Tires
I want to possibly install a 4" suspension lift kit just to fit a 35" 17x9 12.5 bf goodrich KM2 mud terrain. If anyone can think of a cheap but good lift that would help! Or if you think a 3" kit would work then I'll go with that as well. Just need some help to decide.
Old 03-12-2014, 05:15 AM
thkbaron thkbaron is offline
Vehicle: 2011 ram sport crew 4x4
Rep:61
thkbaron will become famous soon enough
get a different tire and save yerself a ton of money then you won't need to worry about a cheap lift! Those tires are crazy expensive and wear horrible. A buddy of mine has them and he didn't have a good experience with them.
2011 Ram Sport 4x4 Crew Cab
Old 03-12-2014, 09:18 AM
DonT DonT is offline
Vehicle: 2015 Ram 3500
Trim Level: Tradesman
Engine: 2013-20?? 409ci (6.7L) Cummins Turbo Diesel 385hp 850lb/ft (Aisin ASC69RC Automatic)
Rep:23
DonT is on a distinguished road
I am not sure you need a lift kit for 35" tires. I think a 2.5" level and the tires and wheels you are looking at would work well. I have use those tires and have had good luck with them. They are noisy though.
2015 Ram 3500 Crew Cab, Long Box Dually 4x4
2014 Ram 2500 Regular Cab, Long Box, 4x4
Old 03-13-2014, 09:45 AM
Spike Spike is offline
Vehicle: 2013 RAM Big Horn 4x4
Rep:58
Spike will become famous soon enough
You can run 35's with Rough Country's 2.5" front / 1.75" rear kit with a newer 1500. Less than $200 shipped.
2.5" RC Lift, 305 R20's, Winch, Softtoper,
K&N, Pop up in tow, German Shepherd co-pilot
Old 03-13-2014, 10:16 AM
theGSE10's Avatar
theGSE10 theGSE10 is offline
Vehicle: 2013 Ram 1500 4WD Crew Cab
Color: Maximum Steel
Rep:33
theGSE10 is on a distinguished road
You can run 35" with a level but its the width that will cause it to rub, and I'm pretty sure you will rub with 35x12.5's. You will most likely need spacers if you decide to just do a level with those tires.
For 4" lifts there's: BDS and Rough Country are probably the most widely used on this site. Bully's Performance can hook you up with anything you will need (they are in the vendor area at the bottom of the home screen).
There are also 3" body lifts out there but IMO you're better off spending the extra $ to do the suspension lift.
Leveling kits can range from 2.5" front/1.5" rear spacers (~$200) to Bilstein 5100 adjustable front shocks (0-2.8" and ~$220) and even Fox high performance front coilovers (0-2" and ~$390). Once again, If you decide to level I'd go with replacing the stock shocks with Bilstein adjustables....the better ride quality is definitely worth the extra money.
There are also 3/4"-1.5" rear spacers from TGC for anywhere between $35-$70. If you want to level and still add some to the rear.
Hellwig Sway Bar, Green filter, Borla XR-1, Line-X, Bak RollX, JBA TCC Shorty's, Raptor 4" nerf, Hunter Bull Bar, 20" Cree LB, Moroso Catch Can, Bilsteins @ 2.8, Fox 2.0 rear, TGC 1.75 spacer, Air Lift 1000, Bak Box 2, Trinity T1000
Pics: https://www.dropbox.com/sh/ut4enlwx4fslgd8/slpdRXv6z2
Old 03-13-2014, 10:16 PM
LowUFO's Avatar
LowUFO LowUFO is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Sport Crew
Color: True Blue Pearl
Rep:1105
More than what will be required to fit that tire size, what will look appropriate. Perhaps the OP thinks a 4" lift will look the best in his opinion. I know I happen to think that 4" lifts w 35" tires looks perfect.
Simon
Old 03-14-2014, 01:50 AM
Canadian Hemi Pride's Avatar
stance makes her dance?
Vehicle: 2008 Dodge Ram 1500
Trim Level: SXT 4x4
Color: Silver/ Black
Rep:2802
If you want the cheapest route. You will need just 2"-2.8" level. Then Rims with eithor 0 or -12 Offset. I am 35/12.50/17 Toyo open country M/T with 17X9 XD Addicts with -12 Offset. No offset.
Tow mirrors up for the haters
Old 04-04-2014, 04:13 PM
boomerboomer boomerboomer is offline
Gender: Not Specified
boomerboomer is on a distinguished road
Default Body lift fan
Big fan of body lift. Very happy with it on my 09. Like a stock truck. No warranty issues. Even level kits have problems and warranty issues. I can post pictures if you want.
Old 04-04-2014, 04:21 PM
Default Pics
My 09 with just a body lift, 20 atx artillery and 35 nitto trail grapplers. Trail grapplers lasted over 60 k plus but not great in the rain. Terra grapplers didn't last and didn't look nearly as good but handled much better in the rain.
Old 04-04-2014, 04:24 PM
Default More pics
More pics. Notice the "ass up" look in this pic. To nervous to do the level kit.
