Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 3.6 Liter Pentastar V6
Custom Dodge Ram Performance Mods - Engine - 3.6 Liter Pentastar V6 Discuss modifying your Dodge Ram with Performance Parts and Accessories!
Factory Spec: 3.6-liter V6 engine - 305 horsepower, 265 lb-ft of torque.
Old 03-10-2014, 03:52 PM
PaulBx PaulBx is offline
Vehicle: 2014 Ram 1500
Rep:20
PaulBx is on a distinguished road
Default How do mods affect the warranty?
I'm wondering about installing a bypass filter and maybe a transmission cooler and maybe an aluminum differential cover. I was just wondering, with all the modding going on around here, what the Dodge policy is for warranty work? Are they going to try to get out of doing it if they see your truck has any mods? Or if you put 5w30 oil in it?
Old 03-10-2014, 03:56 PM
finn5033's Avatar
finn5033 finn5033 is online now
Vehicle: 2014 Ram 1500 cc 4x4
Trim Level: Outdoorsman
Color: Granite
Rep:32
finn5033 is on a distinguished road
I had the same question regarding mods so I called my dealer. According to the service mgr if you change parts they need to be mopar and installed by a certified mopar service shop to be covered under warranty. If you put aftermarket stuff on your truck and there is a failure they need to be able to prove it was that part that caused the failure for warranty to be void. That is just what I was told.
Old 03-10-2014, 05:34 PM
Rep:2616
what would the bypass filter be for ??
__________________________________________
I can not see a differential cover being a factory warranty issue
aluminum cools off the liquid faster, which is always a good thing
most after market covers hold more liquid then the OEM covers
the thing that i like about the after market covers, is that they have a Magnetic Drain Plug, a fluid change no longer requires a cover removal, unless there are excessive metal filings on the drain plug magnet
I have the MAG Hytec cover
Old 03-10-2014, 07:37 PM
Hermes1 Hermes1 is offline
Vehicle: A Truck
Rep:2549
If you were to have a failure of some sort, the dealer service would have to prove the mod you added caused the failure. So to use the differential cover as an example, if your tranny failed they cannot deny a warranty claim for the tranny because you installed a aftermarket diff cover.
Old 03-11-2014, 01:29 PM
Rep:20
Here is the bypass filter I am thinking of. I have installed one before in a Sprinter van.
http://www.amsoil.com/shop/by-produc...?code=BMK21-EA
The point, among other things, would be to extend the oil change interval. I'm guessing that sort of thing is not going to fly with them if I have an engine problem. Maybe I will just go with the recommended oil and change intervals except go with synthetic, and if I have an issue simply remove the bypass filter before taking it in...
Old 03-13-2014, 11:15 PM
ahill37's Avatar
ahill37 ahill37 is offline
Vehicle: 2014 Ram
Trim Level: Bighorn
Rep:19
ahill37 is on a distinguished road
It may be a challenge to install a bypass filter on the 3.6, it uses a cartridge style filter on top of the engine.
3 Ram/Dodges, 1 Jeep, 2 Chevy's, I'm sure my wife believes me when I say I need all of them
Old 03-14-2014, 12:00 AM
Rep:20
Dual remote, maybe. But for the bypass only, all you need is an oil pressure or (possibly) an oil temp sender unit to tap into.
