Old 03-10-2014, 03:40 PM
shanealan5 shanealan5 is offline
Vehicle: 2001 Dodge Ram 1500 5.9 Sport
Color: Blue
shanealan5 is on a distinguished road
Default This might rub some of u guys the wrong way
without going into details i have had some health issues and i am working with pennies....I just bought this truck a little over a month ago i have alot of body work to do im asking u guys for your opinions after i treat the rust i want to fill the holes with expanding foam cut the foam back cover with fiberglass mesh so i waste as little bondo as possible after the foam falls out do u think that the fiberglass patch will hold or will cave in and fall out there are some pretty large holes? will Professional Gold Bondo Body Filler work or do i need something else? Im a newbee to body repair appreciate all comments! Im not worried about the tailgate prolly just replace that
File Type: jpg 1012944_714155278604487_173150569_n.jpg (57.5 KB, 31 views)
File Type: jpg 1964800_714155371937811_826455437_n.jpg (77.3 KB, 22 views)
File Type: jpg 1962689_714155331937815_1137604731_n.jpg (59.9 KB, 20 views)
Old 03-10-2014, 07:57 PM
Jbaker72157's Avatar
Jbaker72157 Jbaker72157 is offline
Vehicle: 2011 Ram Outdoorsman
Trim Level: Outdoorsman
Color: White/Mineral Gray
Jbaker72157 is on a distinguished road
Just experience from buying a car someone did this to. The expanding foam generally won't fall out and it holds moisture and will make it rust worse than it already was. Mine was a 74 Dart and both rocker panels were done this way. To answer your question, if you layer the fiberglass and have good adhesion it will hold.
Old 03-11-2014, 12:29 AM
Color: Blue
Default not permanant
thank you for your comment i dont plan on it being a permanant fix ill probably replace the whole box sooner or later but the longr it holds and looks good the longer i have to buy a box i am looking for a polyurethane foam that is water resistant in my search for looking for foam fixes i seen a few cars that beside there frame were completely made out of foam i have no idea how but they were lol
