Old 03-07-2014, 04:15 AM
Aksium's Avatar
Aksium Aksium is offline
Color: Blue
Rep:18
Aksium is on a distinguished road
Default probably stupid question
Are there any lift setups that don't require a spacer or block to achieve lift such as the 6" lifts it seems all use a spacer to achieve the 6" front
Old 03-07-2014, 08:49 AM
followme2dq's Avatar
followme2dq followme2dq is offline
Vehicle: 2006 Dodge Ram SRT10 rc
Trim Level: srt 10
Rep:53
followme2dq will become famous soon enough
I know they make 6" lift front coil springs for the 2500 and 3500. I assume you have a 1500? A coil over kit might be available for the 1500, BDS kit maybe.
06 Ram SRT 10, Black! 13 2500 Big horn Crew Cab for towing and plowing!!!
Old 03-07-2014, 09:28 AM
Aksium's Avatar
Color: Blue
Rep:18
I like the bds coilover but at 4300 not very doable and shipping to alaska would hurt quite a bit as well lol are the coilover kits the only ones that don't utilize a strut spacer?
Old 03-07-2014, 09:36 AM
Campbell402's Avatar
Campbell402 Campbell402 is offline
Vehicle: 2014 Ram 1500
Rep:73
Campbell402 will become famous soon enough
Coil over kits are the only ones that don't use spacers. Most kits also use preload spacers as well and most people take those out and use bilsteins instead.
Old 03-07-2014, 09:50 AM
Aksium's Avatar
Color: Blue
Rep:18
Ok so if I use bilsteins with say zone or rcx will the spacer on top cause issues? Reason I ask is because my shocks are going bad because of the spacers I have now to level it
