Old 03-06-2014, 10:49 AM
followme2dq's Avatar
followme2dq followme2dq is offline
Vehicle: 2006 Dodge Ram SRT10 rc
Trim Level: srt 10
Rep:53
followme2dq will become famous soon enough
Default Lifted (pics) now what tires on stock rims?
2013 Crew Cab 2500 Bighorn. Added leaf to the pack to help out sag when towing.
Before:
After:
Ended up with a substantial rake:
So I ordered Tuff truck 1216V springs and shocks. 2" to 2 1/2" lift for a diesel. I got a hair over 3" being I have the 5.7.
Stock springs on the left new ones on the right:
Ended up with 1" Higher in the rear...28 1/4" ground to top of wheel well, and 27 1/8" front.
Was thinking 315 70 17 or 35 12.5 17. Because I would like to stay with the stock rim for now. Would 325 75 17 be an option?
06 Ram SRT 10, Black! 13 2500 Big horn Crew Cab for towing and plowing!!!
Old 03-06-2014, 12:02 PM
LowUFO's Avatar
LowUFO LowUFO is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Sport Crew
Color: True Blue Pearl
Rep:1105
I think 35 x 12.50 would look awesome on that. But you should talk to BrandonJansen about it. He's a wheel and tire expert on here and he recently traded a 1500 for a 2500. I'll send him a link to this thread.
Simon
Old 03-06-2014, 12:09 PM
Trim Level: srt 10
Rep:53
Awesome!! Thanks!
Old 03-06-2014, 01:28 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
You could probably fit the 325/75/17 if you really wanted to... it would take some work though. And IMO it would looked stuffed so personally I wouldn't go that big. With the leveling kit you'll have no problem running a 35x12.5 on the stock rims. Personally that's what I'd go with, it will look the most proportionate and you shouldn't have any issues with rubbing.
Old 03-06-2014, 01:54 PM
Trim Level: srt 10
Rep:53
Thanks for the Info!
