Old 03-05-2014, 08:56 PM
Ramadian's Avatar
Ramadian Ramadian is offline
Vehicle: 2012 Ram 1500 Sport
Rep:17
Ramadian is on a distinguished road
Default Readylift SST + 5100s
does anyone on here have this setup? i currently have the ReadyLift SST and 35" tires and i want to put the 5100s on to level it out
i just want to see pics and settings of your trucks if you have this setup
Old 03-05-2014, 09:47 PM
Campbell402's Avatar
Campbell402 Campbell402 is offline
Vehicle: 2014 Ram 1500
Rep:73
Campbell402 will become famous soon enough
You should not stack the spacer and the bilsteins. It is to much stress on the front end and will just destroy it.
Old 03-06-2014, 01:09 PM
Wandell's Avatar
Wandell Wandell is offline
Rep:35
That is if you could even get your front end bolted back together. That is the reason a full suspension lift kit has drop down brackets. You can't just stack a spacer on adjustable coilovers and get 4 or 5 inches of lift.
If you want a little more lift inexpensively, add a body lift.
