Old 03-03-2014, 05:34 PM
bimperial1 bimperial1 is offline
Vehicle: 2013 Dodge Ram 1500 Big Horn
bimperial1 is on a distinguished road
Default Another tire/lift question.
After my reading i am going to install that Blistein 5100 struts at a 2.1 raise to level my truck. I do little to no hauling or pulling. I know my first step is to level it out and hope not to void my extended 48/48 bumper to bumper or 7/100 powertrain warranty. I have the stock 265/70/17 chrome wheels on my Big Horn. From the leveling/tire size post is it correct that i can only go up to a 285/70/17 to keep my stock wheel and to not have any rubbing without spacers? Im hesitant to install a 1/4" spacer due to horror stories ive heard from losing 1/4" of your lug nut threads. I am only wanting a 33 or maybe 35. Im sure the true 12.5 width wouldnt happen without spacers or new wheels with an offset. Im looking to get the Hancook Dynapro ATM since i wont be doing any real off-roading. Thanks in advance
Old 03-04-2014, 02:44 AM
Fireblade8's Avatar
Fireblade8 Fireblade8 is offline
Vehicle: 2011 Dodge ram crew cab
Fireblade8 is on a distinguished road
Currently I have a two inch level (5100's are on backorder). I am running 35's 12.5 wide dick cepek mud country on a 20 inch rim with a -12 offset. I do rub slightly on the mudflap only at low speed (basically crawling) turning halfway to the left. The extra lift the bilsteins will give will rectify the rub I'm sure of it. I don't think you will fit a 12.5 wide on stock rims as it will rub. I'm not a fan of spacers from what I've read however can't say for sure cuz I've never used them. I think it may be worth your while to have two sets of rims and tires if its feasible . I use my stock set for winter and my 35's for summer. Any warranty issues I suggest slapping on stock rims and adjusting your bilsteins to stock height when and if you need to bring it in for any big warranty jobs. Hope that hèlps
Old 03-04-2014, 09:00 PM
Do you think a 285/75/17 will fit with blistein leveling kit probably set to 2.1? I believe the width is around 11.8 height is right around 33 which should be fine...
Old 03-04-2014, 09:04 PM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
That tire should be fine, if you would like we can get some new tires and your bilsteins out to you at crazy low prices, our fellow forum members get the best pricing and discounts around, while we do not have either one in our site we can send you a custom cart for checkout if you would like a quote please feel free to reach out to us via PM or by posting in our Vendor Section, you can also email us directly at sales@bullysperformance.com or call us toll free at 855-432-FAST we are always more than willing to help out forum Members, just remember if you contact us off of the boards to mention you are a Z member to insure you get the best discounts
Thanks
Jeremiah
Old 03-04-2014, 11:52 PM
Fireblade8's Avatar
Yah Jeremiah is right. 285-75R17 is equal to 33.8-11.2R17. Probably wouldn't even need to use a level as 33's are basically stock. I will still always recommend a level though as i think a truck should sit level. 2.1 would be perfect
Old 03-05-2014, 01:47 AM
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
I agree trucks do look best when leveled
Thanks
Jeremiah
Old 03-05-2014, 01:14 PM
My stock is a 265/75/17 I believe
Old 03-05-2014, 05:35 PM
Fireblade8's Avatar
265 is the width 75 is the sidewall hight (aspect ratio to width) so 285 is only 15mm larger than your stock tires. Not much bigger
Old 03-05-2014, 05:50 PM
fire do you think I could a 35 then? I think with stock wheels without spacers the width will be the issue? So if I could find a 35 thats not an actual 12.5. I really just dont want to spend the money on 4 tires and 4 new wheels.
Old 03-05-2014, 06:10 PM
Fireblade8's Avatar
I believe several tire companies have a slimmer tire. Toyo at2 come in a 35 x 11.8 (34.4 true) and will fit without rubbing with your shocks set at 2.1 35's look so much better I think
Last edited by Fireblade8; 03-05-2014 at 06:13 PM. Reason: Phone froze while completing
