Old 03-02-2014, 08:15 PM
012RAMbo's Avatar
012RAMbo 012RAMbo is offline
Vehicle: 2012 Ram 1500 CC
Rep:264
Default Added to lift and ordered new wheels and tires!
Hey guys, what's up. Well here goes on a pretty long post! I have had a CST 4'' lift on for 6-8 months and finally upgraded to a 6'' and ordered new tires and wheels also. Here is a pic of my truck stock at ride height, and then how the truck looked with the 4'' spindles and 1.5'' rear spacer.
I ordered my tires and wheels from Andrew at Bully's. They should hopefully be here within the next few days. I got my AMP steps from him a few months ago and had a great experience. They beat all prices I could find on the internet with both of my purchases. For the tires, I went with the Mickey Thompson ATZ P3 35x12.50r20. And the wheels are going to be black Fuel Mavericks 20x9 +1mm offset. I also ordered some BORA 1.75" wheel adapters for the rear wheels. I went with the 1.75 so I hopefully wouldn't have to cut my stock studs. I know with the 1.5'', you have to trim a little off the studs to get the new wheels on. The front wheels were pushed out just a little over 1.5'' with the new spindles, so hopefully that quarter inch in the back wont be noticeable. I will have some solid info on those when they come in in a couple weeks.
Adding to my lift, I used a 2'' Daystar spacer up front. And out back, I did away with the 1.5'' CST billet spacer and went with the Pro Comp 4.5'' lift kit with Bilsteins. I finished up yesterday, and will get my alignment done tomorrow. I took some fender measurements after install, but I drove it about 25 miles to let everything settle in for the alignment, and seems to have settled about a 1/2'' in the front. Front: 42.25'' Rear: 43"
And here are some pics after the lift install.
I know you guys like pictures, hell who doesn't! If you have a 2wd and are wanting to know anything, I will do my best to answer any questions. Thanks!
Cabin Air Filter -Debadged -14" Magnaflow -Mopar T Grip Shifter -Foxbox w/ 10" Type Rs -B Pillar tape removed -Tint matched - Rear level - 22'' SRT-10 reps on 305/45/22 nitto 420s -AMP Power Steps - Custom retro headlights
Old 03-02-2014, 10:08 PM
RockemSockemRambot's Avatar
RockemSockemRambot RockemSockemRambot is offline
Rockin the Burbs
Vehicle: 2014 Ram 1500/ 06 Ram 1500
Color: Clear Black
Rep:28
RockemSockemRambot is on a distinguished road
That's going to be a good looking truck when you're done. White trucks look better and better the more I see them.
2014 Ram 1500 HEMI Sport CC 4x4
2006 Ram 1500 HEMI SLT QC 4x2
Old 03-02-2014, 10:27 PM
05cr125r's Avatar
05cr125r 05cr125r is offline
Vehicle: 2012 Big Horn QC
Trim Level: Big Horn 4x4
Rep:103
great looking truck...nice install
Mods; Line X, Bilsteins set at 2.1, Magnaflow 18", Debadged , Cool White LED Interior, LED license plate, Cool White LED reverse, Fronts tinted 20 %, Stubby Antenna,AVS WindowVisors, Black Honeycomb Grille Insert, Green Performance Air Filter
Old 03-02-2014, 10:59 PM
012RAMbo's Avatar
Rep:264
Thanks guys!
Old 03-03-2014, 05:25 PM
012RAMbo's Avatar
Rep:264
Update: Got the alignment and wheels and tires put on this morning. Drives great, no vibrations and these tires are quiet. I can only hear them, barely, at highway speeds.
Old 03-03-2014, 05:44 PM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
Damn those look good, I am happy they arrived and you got them installed!
Eric
Old 03-03-2014, 05:57 PM
012RAMbo's Avatar
Rep:264
Eric
Yea, I am very happy with them. Thank you guys for the great deals!
Old 03-03-2014, 06:54 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
Nice!! Looks very good. I'm definitely a fan of the milled Mavericks, they're on my list for when I order wheels for my truck.
Old 03-03-2014, 07:52 PM
012RAMbo's Avatar
Rep:264
Thanks Brandon. I have always liked them from when I first started looking months ago. Then I got overwhelmed looking at so many different ones, I finally decided on these. Clean and simple look.
Old 03-03-2014, 09:14 PM
Rep:2026
Ya I know what you mean. I've probably changed my mind about 3 or 4 times since on what I want to run on my 3500 and I'm sure I'll change it again. I think what I might end up doing is printing out some pictures of all the ones I'm considering, hanging them up on the wall in my office, and them start to eliminate the ones I get sick of first.
I agree that I like the simple look of them though. Nice and clean looking and much easier to wash as well
