Old 03-03-2014, 08:19 AM
DonT DonT is offline
Vehicle: 2015 Ram 3500
Trim Level: Tradesman
Engine: 2013-20?? 409ci (6.7L) Cummins Turbo Diesel 385hp 850lb/ft (Aisin ASC69RC Automatic)
Rep:23
DonT is on a distinguished road
No lockers for front or rear that I know of. Too bad, I would seriously consider putting them in if I could get them.
2015 Ram 3500 Crew Cab, Long Box Dually 4x4
2014 Ram 2500 Regular Cab, Long Box, 4x4
Old 03-03-2014, 03:45 PM
Thunderhorse's Avatar
Thunderhorse Thunderhorse is online now
The Sound of Eight Hooves
Rep:532
Thunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of light
The 4x4/LSD setup I have is fine for my needs, and the LSD is probably more practical for me to have given the type of driving I usually do, but it would be pretty cool to have a front locker.
Honestly, whoever gets to market with aftermarket diff options for these ZF axles could make a ton of money because there are a lot of people who want to add lockers, LSD, or even just re gear. I don't understand why someone hasn't done it yet since there are several model years this applies to, the ZFs aren't really that new, and Ram's market share is only increasing plus Ram doesn't offer factory lockers like Chevy and Ford do.
Huskyliner Weatherbeaters, door edge guards, Line-X bedliner, Kryptek Typhon Cordura seat covers w/ MOLLE panels (review), Console Vault (install/review), Bilstein 4600s (thread), BFG T/A KO2 LT275/60/20s (thread), Borla XR-1 (thread), Matte black Plasti-dipped center console bezel, BT catch can.
Old 03-05-2014, 05:11 PM
karl66 karl66 is offline
Vehicle: 2013 ram
Trim Level: laramie
karl66 is on a distinguished road
Thanks for all the input and good information. Called west coast differentials today and the told me to call ARB directly. Too late today will call on thurs and when I get info I will post it.
Old 03-09-2014, 02:41 PM
PostalTwo PostalTwo is offline
Vehicle: 2014 Ram 1500 Crew 4x4
Trim Level: sport
Color: maximum steel metalic
Rep:14
PostalTwo is on a distinguished road
I called eaton , makers of detroit lockers and they dont make them .for 4th gen
2014 sport hemi 4x4 with 8speed bone stock max steel metallic and love it!
Old 03-10-2014, 08:56 AM
preachp's Avatar
preachp preachp is offline
Vehicle: 2013 RAM 1500
Color: White and black
Rep:79
preachp will become famous soon enough
Hi All,
Do I have a weird truck here? The reason I ask is that I have the LSD diff and when the left rear spins the right rear locks in. It doesn't matters if I'm tar, sand, snow, or ice. I KNOW it locks because it tries to kick the truck back to the left side. There is some info that says the extent of the lock on the clutch will be determined by the amount of torque on the left wheel when it starts to slip. This also has not been my experience. When it engages it engages. I would still like to have a locker option but this lsd is miles ahead of the setups I had in some of my older cars.
Still full lockers front and rear would be awesome.
preachp
Philippians 4:13 I can do all things through Christ which strengtheneth me.
MODS: Kenwood DNX570 HD, Jeraco Hirise cap, black 4" nerf bars, Ultra Baron wheels, BFG Rugged Terrain A/T tires, Spyder smoke headlights and red smoke LED taillights, Bumble Beast stripe.
Old 03-10-2014, 05:40 PM
Rep:532
Preachp, its a helical gear LSD, not a clutch pack. They changed the design from clutch type for the 2013s.
In case you're wondering, I do not know the bias ratio on these LSDs but I would love to find out.
Old 03-14-2014, 09:15 AM
preachp's Avatar
Rep:79
Hi Thunderhorse,
It seems to me that when it locks, it locks. I did a burnout on ice to see what effect I could expect from the rear end when it kicked in and it laid down two nearly equal strips in the ice. So I did a hard start on tar and again two nearly equal length tire marks. So based on this pretty unscientific test I would say that what your putting down goes to both rear wheels. Also it would indicate to me that there isn't much rotation required to lock it in.
Thanks for the info on the engagement system. It really felt strange for a clutch system to engage so abruptly and harsh, but helical gear engagement makes a lot more sense.
preachp
Old 03-24-2014, 06:38 PM
Trim Level: sport
Color: green
Rep:657
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
op, nothing aftermarket yet. why do you think you need a locker for upstate ?
