Old 02-28-2014, 01:49 PM
karl66 karl66 is offline
Vehicle: 2013 ram
Trim Level: laramie
karl66 is on a distinguished road
Default Dodge newbie Off road advice
New Dodge owner with 2013 Laramie with air suspension and 8 speed. Love the truck. Put in S&B cold air after reading about it here, very happy with results. Can anyone offer oppinion on a locking rear, air or electric. Mine has locking rear but it is a limited slip. Take the truck upstate NY and need a true locking diff. Any help appreciated. Will post pictures as soon as possible. Also swapped stock rubber with 305 55 20 Dick Cepeck fun countries. They are all terrain but work well in the mud with just a little road noise.
Old 02-28-2014, 02:35 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:418
hydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nice
If you go alone into really tough areas, maybe a winch and a chain saw. I've used a saw to cut blocking, trees across the road,etc. Rope or some tow straps. I have a rope come along that has saved my but a few times. The better your traction, the worse that you will be stuck eventually. I've only had to use my front mounted winch a couple times, but it saved my ass. Of course if you go with other guys, you may spend a lot of time hauling them out.
Inertia Spartan Plus cam, Circle D 3,000 rpm stall converter,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's,3:92's, extra rear leaf.Line-X Bedliner, 210,000 miles To Hell and back. 14.2/96 mph NEDW
Old 02-28-2014, 04:44 PM
Vehicle: 2013 ram
Trim Level: laramie
Great advise. We do that when exploring new areas. The place we have trouble is on the washout going to the property. One guy has a real locking rear and has a lot easier time. Just wondering if its worth the effort and cost to upgrade. When there is snow and mud in the spring we use chains. Thanks for the help.
Old 02-28-2014, 05:28 PM
Rep:2616
The current rear ends are called ZF 245 MM REAR AXLE (differential)
applications
Chrysler 9.25" Rear "ZF" '10 & Up
2011 & Up Ram 9.25
2010 & Newer Grand Cherokee & Dodge Durango
rear axles before the ZF was called
AAM Corporate 9.25 rear differential for the Dodge Ram 1500
Gear manufacturing companies, ( like Yukon Gear, Eaton, Auburn Gear, etc. ) have not exactly leaped to make parts for the ZF differentials
Old 02-28-2014, 10:13 PM
Thunderhorse's Avatar
The Sound of Eight Hooves
Rep:528
Thunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of light
What do you mean by this?
Huskyliner Weatherbeaters, door edge guards, Line-X bedliner, Kryptek Typhon Cordura seat covers w/ MOLLE panels (review), Console Vault (install/review), Bilstein 4600s (thread), BFG T/A KO2 LT275/60/20s (thread), Borla XR-1 (thread).
Old 03-01-2014, 11:09 AM
nfd538's Avatar
nfd538 nfd538 is offline
Vehicle: 2012 sport crew
Trim Level: sport crew
Rep:16
nfd538 is on a distinguished road
You either have a limited slip or an open diff there is no locking limited slip. Maybe try putting a more aggressive tire on.
BT catch can, 20% tint, Leer 100xl top, Aero 3030xl
Bilstein 5100, Duratracs 275x65x20 (winter), 20" SRT & 275x55x20 Nitto terra graps (summer), InTune DCX, MagHytech diff cover
Old 03-01-2014, 03:49 PM
Vehicle: 2013 ram
Trim Level: laramie
Default rear diff
Sorry wasnt clear on that, button on dash says lock but its not a fully locked rear its a limited slip. Would like to know if anyone has put in a air locker or electric locking rear.
Old 03-01-2014, 04:39 PM
Rep:528
The diff is limited slip, the button that says 4 lock on the dash is referring to the transfer case.
Old 03-02-2014, 11:08 AM
h2oman's Avatar
h2oman h2oman is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Express 4X4
Rep:308
I've looked for some time and I can't find lockers for 4 Gen Rams. I don't think they exist. I hope someone proves me wrong.
333Half the beast
I used to be
Old 03-03-2014, 12:21 AM
PostalTwo PostalTwo is offline
Vehicle: 2014 Ram 1500 Crew 4x4
Trim Level: sport
Color: maximum steel metalic
Rep:14
PostalTwo is on a distinguished road
unfortunately your right no locking option for 4 gen rams (until they make one )
2014 sport hemi 4x4 with 8speed bone stock max steel metallic and love it!
