Old 02-24-2014, 12:57 PM
PhilW1986 PhilW1986 is offline
Vehicle: 2007 Dodge Ram 1500 Laramie
PhilW1986 is on a distinguished road
Default what offset?
Hey yall, quick question... I just ordered my Rough Country 6inch lift for my 07 1500 Laramie... What offset rim should i run to have that nice wide stance? Just enough so the wheels/rims stick out past the body of the truck
Old 02-24-2014, 01:00 PM
gonefishin776's Avatar
Rep:1900
with a 6" lift I'd go with a -24mm offset
here is what a -12mm looks like with just a level. i'd go -24 though for a high lift.
Giants89's Avatar
Giants89 Giants89 is offline
Vehicle: 2010 Dodge Ram 2500
Trim Level: TRX 4
Color: Blue
Rep:48
Giants89 is on a distinguished road
A -12 offset should suffice, if I' am not mistaken.
DPF Deleted_H&S performance EGR Delete_5" turbo back exhaust_RaceMe tuned_35x12.5 Nitto's_Recon Tails & 3rd Brake light.
Old 02-24-2014, 01:01 PM
Rep:1900
it wouldn't be bad.
but anything over a 4" lift and I think you need them to stick out a bit more to get the stance/proportions right.
as i said about, a -24mm would be best IMO
Old 02-24-2014, 01:02 PM
Giants89's Avatar
Trim Level: TRX 4
Color: Blue
Rep:48
Correction! Yes I would have to agree with gonefishin, a -24 would be much more appropriate on a higher lift.
Old 02-24-2014, 01:07 PM
Rep:1900
mhmm.
however, say I went and installed a 6" lift. I wouldn't go buy new wheels just to get a -24mm offset. I'd keep my -12mm and I'm sure it would look just fine
BUT since he's in the market and has the option, i'd say -24
Old 02-24-2014, 01:18 PM
Cool, Thanks guys..
Old 02-24-2014, 01:32 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
The amount one offset will stick out from another also depends on the width of the wheel. A 20x9 -12 offset does not stick out as far as a 20x10 -12 offset. That's something you need to keep in mind. You can't just throw up a -24 offset without stating the width of the wheel, they go hand in hand.
OP what size wheels are you planning to run?
Old 02-24-2014, 01:38 PM
Rep:1900
very true very true.
always forget that important detail.
my rims are only 8.5" wide so if OP gets a 9" or even 10" wheel. a -12mm might actually be good on the 10"
Old 02-24-2014, 03:22 PM
huff73541 huff73541 is offline
Vehicle: 2007 Ram 1500 Big Horn
huff73541 is on a distinguished road
Agree with gonefishin776
07 Ram 1500 with 6" Rough Country
20x10 -24mm
