Old 02-23-2014, 05:45 PM
shawnwhite78 shawnwhite78 is offline
Vehicle: 2014 1500 quad cab
Trim Level: express st
shawnwhite78 is on a distinguished road
Default motofab lifts
hey guys im looking at using a motofab lift probly a 3 inch front and a 1.5 or 2 in the rear does anyone have any input on this? im lookin to put a set of 35's on as well. also is there a need for spacers so I can use the stock 20s its on a 2014 ram 1500 quad cab, heres a link http://www.motofablifts.com/2009-201...p/dr-3f-2r.htm
thanks for any advice im new to all of this, cheers
Old 02-24-2014, 04:45 PM
so nobody has any info on wheel spacers to fit 35x12.5 on the stock 20 inch wheels? like what size spacer/which brand to use? im sure someone on here has done this, just need to get the info so I can order parts this week.
thanks for the help
Old 02-24-2014, 04:59 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
you'll need 1/4" spacer.
not sure what brand, where people usually get these. i would just stay away from cheap ebay ones.
you get what you pay for.
Old 02-24-2014, 05:26 PM
So is this a situation where a 1/4 in spacer is enough to clear the control arms and still retain stock studs, if you go thicker you would need to go thick enough to equal stud length? I would like to have the tires stick out a bit but not crazy, would an 1.5 spacer work for me? Can anyone post some pics of 35s on stock 20s. Thanks guys
Old 03-18-2014, 04:28 PM
All done NO spacers needed to fit 35s on stock wheels with this set up.
35s on 20s, leveling, lift
