United Radio
Old 02-22-2014, 08:30 PM
primo spaghetti's Avatar
Vehicle: 2014 Ram Sport
Color: Maximum Steel Metallic
Rep:910
Default factory rim/spacer for 35x12.5x20
I tried a search, but got lost! lol
If i recall correctly, the factory 20x9 sport wheel requires a 1/4" spacer to clear 35/12.50/20 wheels?
any help would be greatly appreciated.
thanks!
Old 02-22-2014, 08:49 PM
Campbell402's Avatar
Campbell402 Campbell402 is offline
Rep:73
Campbell402 will become famous soon enough
Yes this is correct 1/4 spacer to clear the 12.50 width
Old 02-22-2014, 09:19 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:1969
brandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant future
What tires are you planning on putting on? 1/4" spacers will work with factory rims if you're planning on an AT tire. If you're looking at Toyo MT's or Nitto Trail Grapplers I'd recommend aftermarket rims since they actually measure about 13.4" wide when mounted.
8" BDS Long Arm Lift with Fox 2.0 Shocks | Dual Fox 2.0 Steering Stabilizer | 37x13.5 Toyo MT's | AMP Powersteps & Bedstep | Bakflip G2 | Mag-Hytec Rear Diff Cover
EST 500 hp/1268 ft-lbs at FW | H&S MiniMaxx Custom Tuned | 4" Flo Pro Stainless TBE | Sinister EGR Delete | ARP 425 Head Studs | 4.56 AAM/Yukon Gears | S&B Intake w/ Scoop
Old 02-23-2014, 10:31 AM
Rep:910
thanks guys!
brandon i was looking at either the pro comp extreme at or extreme mt2.
i thought is 1/4 was all indeed then i would look at the spacer, but I'm not interested in going any bigger with a spacer.
i just am having a hard time find a wheel i like! lol
Old 02-24-2014, 12:27 PM
Rep:1969
With either of those you should be fine with 1/4" spacers on the stock wheels. There is a company that makes 3/8" hubcentric spacers as well but I forget the name of it off the top of my head... I want to say it starts with an "M". If I remember what it is I'll come back and post it up.
Ya finding wheels can definitely be a pain... there's just so many to choose from and to find one that's the exact look you're going for can take some time. The new Sport wheels do look very nice though!
Old 02-24-2014, 06:16 PM
Rep:910
thanks..
Old 02-24-2014, 09:44 PM
Boosted's Avatar
Boosted Boosted is offline
Trim Level: Outdoorsman
Color: Black/Mineral Gray
Rep:219
Motorsport-Tech offers hub centric wheel spacers for our trucks.
Old 02-25-2014, 06:29 AM
Rep:910
what makes a hub centric spacer different? sorry this is all new to me?
Old 02-25-2014, 12:36 PM
Rep:1969
Hub centric centers the wheel (and spacer in this case) on the hub of the truck rather than the lug nuts. By doing so it puts less stress on the studs and lug nuts and keeps the wheel centered on the hub properly. Many vehicles that have lug centric wheels rather than hub centric ones will experience a slight wobble or vibration at certain speeds. It's nothing terrible but it's not something you want if you can avoid it.
If you're looking at aftermarket wheels at all too most of them will come with a standard hub bore and then will have a hub adapter ring to make them hub centric to your vehicle. Make sure you get those rings if you order aftermarket wheels.
Old 02-25-2014, 05:34 PM
Rep:910
thanks brandon...thats a great explanation...
interesting...these adaptor rings, they don't come standard with the rim? thats bizarre to me! I'm guessing without them you might get tat slight shimmy you described aswell?
