Old 02-22-2014, 12:01 AM
Chopper's Avatar
Chopper Chopper is offline
Vehicle: 2011 Ram quadcab
Trim Level: sxt
Color: red
Rep:13
Chopper is on a distinguished road
Send a message via Yahoo to Chopper
Default Steering wheel shimmy.
Well last night on the way home from work I noticed a shimmy in the steering wheel, almost like a shake. I could let go of the wheel and truck seemed to go straight but wheel was jerking back and forth. This morning it seemed like it wanted to steer by itself but not real serious. I decided to shut the radio off to hear if there was any noise. None until I got in the parking lot and when I turned the wheel it was a good clunking and grinding noise from the front. Took it to the dealer and found out my front axle was shattered ! The truck has like 54000kms on it. Not real impressed, so far I have a leaky rear window grinding door hinges and now a shattered axle. First new Ram I have ever bought (new in 2011). I always bought new Fords but liked the looks and power of the Ram so thought I would try something different as I have always been a MOPAR car guy. Might go back to FORD.
Old 02-22-2014, 03:16 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:427
hydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nice
If its actually a front wheel bearing, hub assembly, all 4x4 pickups are prone to failure, regardless of brand. I have almost 200K on my Ram, still ok, my dad had 2 fail on his 06 Sierra 1500. I'll bet the same manufacturer makes em for all the makes, at least the bearings. Spray some lube on the door hinges, I spray mine at every oil change.
Inertia Spartan Plus cam, Circle D 3,000 rpm stall converter,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's,3:92's, extra rear leaf.Line-X Bedliner,GY Armortracs, 210,000 miles To Hell and back. 14.2/96 mph NEDW
Old 02-22-2014, 05:07 PM
Ramzaq Ramzaq is offline
Vehicle: 2009 Ram CC 4X4
Trim Level: SLT, Big Horn
Color: Black Pearl coat
Rep:233
Ramzaq has a spectacular aura aboutRamzaq has a spectacular aura aboutRamzaq has a spectacular aura about
Pretty much what Hydrex has said. The only thing I would add to that would be none of the big three truck makers have figured out how to properly seal the third brake light on the cab to stop them from leaking.
Old 02-22-2014, 09:33 PM
Chopper's Avatar
Trim Level: sxt
Color: red
Rep:13
Well got a call from the Dealer yesterday, front axle was shattered. The service manager was holding chunks of it in his hand when he called me. I could understand if this truck was used as a truck but I NEVER drive it off road. The hinge is to be replaced because it is not to specs. That's what I was told anyway. lol. Anyway they gave me a 2013 Charger to use for the weekend nice car, just doesn't have the Hemi. lol
Old 02-22-2014, 09:51 PM
Jstin's Avatar
Jstin Jstin is offline
Vehicle: 2011 RAM 1500 4x4 Sport 5.7
Jstin is on a distinguished road
Search "3rd brake light leak" for that fix.
I hope your axle issue is covered under warranty still.
2011 RAM 1500 Sport 4x4 5.7 3:55 Gears, 18" Magnaflow, Drop in K&N filter, BT CC, TonnoPro Lo-Roll, front tow hooks, cabin filter, Moes 85mm TB, Homemade CAI, Bilstein leveled 2.1", tailgate assist. AVS in channel visors, Magnaflow Y pipe, DiabloSport DCX inTune I-1000, HF tune
Old 02-22-2014, 10:02 PM
Jstin's Avatar
In less than 3 years? Assuming normal use.
I Spray some lube on the door hinges, I spray mine at every oil change.
Good to know.
Old 04-09-2014, 11:51 PM
Chopper's Avatar
Trim Level: sxt
Color: red
Rep:13
Yeah they fixed my Ram, replaced the axle. Had one in stock, thought that was kind of odd but I'm happy.
Old 04-11-2014, 04:57 PM
huntergreen huntergreen is online now
Trim Level: sport
Color: green
Rep:652
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
Hydrex, what lube do you use on your hinges? tks
Old 04-11-2014, 04:58 PM
Trim Level: sport
Color: green
Rep:652
chopper, what did they fix, axle or bearing. was it covered under warranty?
Old 04-11-2014, 08:49 PM
gysnst2's Avatar
gysnst2 gysnst2 is offline
Vehicle: 2011 Dodge Ram Laramie CC 4x4
Color: Deep water blue pearl coat/Light Graystone Pearl
Rep:13
gysnst2 is on a distinguished road
Use a good bike chain lube not from walmart either lol. it goes on like water and coats the inside of the Hinge with wax. Keeps the Hinge from rusting and it keeps the squeaks down. Bike chain wax also cleans the hinge while it lubericates it. No mess except a few drips. But you catch those.
AVS bug guard, Mopar rubber mud flaps, Mopar vent visers, Snugtop cap, Remote tailgate lock, 392 LS, VHT tail lights, 9" LCD headrests, Debaged sides, tinted 20% front 35% rear, cabin air filter mod, topguncostumz 2,25 rear lift coils, bilstein 5100 set at 2.8, and bilstein 5100 rear shocks
