Old 02-20-2014, 12:40 AM
ChaseRam ChaseRam is offline
Vehicle: 2013 ram 1500
Rep:14
ChaseRam is on a distinguished road
Question Need Help on Correct offset and backspacing for 35" trail Grapplers with Pocket flares
Hi everybody this is my first post here so go easy on me. I have a 2013 ram crew cab, i have a handful of things I'm going to be putting on and that includes a level and Bushwacker Pocket style flares. I want to run 20" rims (probably black fuel Hostages) on 35" trail grapplers. This leads to my question, what would be the proper width, offset and backspacing to get the new rims & tires flush with the pocket flares? I don't know if all three of those are relevant to getting the tires flush but any knowledge or experience would be appreciated (also pics of your trucks too)! Thanks
Old 02-20-2014, 03:20 AM
Boosted's Avatar
Boosted Boosted is offline
Trim Level: Outdoorsman
Color: Black/Mineral Gray
Rep:219
I would say a 20x9 wheel with et-12 offset would be perfect.
Old 02-20-2014, 06:58 AM
macc08's Avatar
macc08 macc08 is offline
Rep:722
check out brandonjansens thread here.
It contains all the info you need, and if it doesn't that guy pretty much knows everything this subject.
But i would say that the -12 offset would be pretty close.. My wheels are -12 and 9" wide, and they sit about 2" outside the fender.
Old 02-20-2014, 01:33 PM
brandonjansen's Avatar
brandonjansen brandonjansen is online now
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
20x10 -12 offset to be flush with the flare
20x10 -24 offset to be sticking out slightly past the flare
With either one you will need at least a 2.5" level and you'll still end up doing a bit of trimming. But it will be worth it.
Old 02-20-2014, 02:44 PM
Jpeetro's Avatar
Jpeetro Jpeetro is offline
Vehicle: 2009 Dodge Ram
Trim Level: SLT 4X4
Jpeetro is on a distinguished road
I just did 17x9 wheels -12 offset with 315/70/17 tires (12.50 width). Looks perfect with my pocket flares. Anymore or less offset would look off in my opinion.
Old 02-20-2014, 05:17 PM
boomer135 boomer135 is offline
Vehicle: 2013 Ram
Trim Level: 4X4 CC Sport
Rep:39
boomer135 is on a distinguished road
I agree 100%. I have fuel 20x10 -12 with 315/60 Toyo OC MT's a true 12.5 wide. The BW pocket flare is 2 1/2" of coverage.
Although we all have different taste, this is what looks best to me, not too much but just enough...
MODS: PE Full Metal Jackrabbit, BT Catch can, Magnaflow 18", Vararam, Bullydog Hemi Tuner, Zone 1.5 BL, Bilstein 5100's @2.8, TG 1.5 rear coil Spacers, Fuel 20x10 -12OS, Toyo OC MT 315/60R20, Painted BW Pocket Flares http://www.ramforumz.com/showthread....88#post1344588
Old 02-21-2014, 01:20 PM
Rep:14
Thanks guys I think I'm going to pick up some 20x10 fuel hostages with a -12 and either throw on 315s or 35x12.5s on. Once I get some stuff done I'll post some pics!
Old 02-21-2014, 08:53 PM
Vehicle: 2013 Ram
Rep:39
Is your final decision a nitto or toyo tire? Be sure to look up the actual sizes, the nitto trails run wider than the toyo open country mt's
Old 02-23-2014, 12:40 PM
primo spaghetti's Avatar
Vehicle: 2014 Ram Sport
Color: Maximum Steel Metallic
Rep:910
looks nice boomer...
got a side profile pic?
Old 02-23-2014, 02:11 PM
Vehicle: 2013 Ram
Rep:39
Here are some pics on level surface, and flexing the suspension a bit.
35s, backspacing, offset, pocket style
