Old 02-17-2014, 10:48 PM
boomer135 boomer135 is offline
Vehicle: 2013 Ram
Trim Level: 4X4 CC Sport
Rep:39
boomer135 is on a distinguished road
Default DIY Rear coil spacer install
This install should take you 30-60min to accomplish, Having someone help is always a plus, but I did it on my own…
Chock front wheels & Jack up rear one side at a time and support with jackstands. I used 2 per side for safety reasons. remove rear wheels.
Using a wood or rubber support Jack up center of rear axel with enough pressure to remove parts in next step. Keep floor jack with pressure under rear axel
Remover the lower shock mount bolt/nut and remove sway bar end links. Repeat for other side. Swing these out of the way
Slowly let the jack down, lowering the rear axel enough to remove the coil springs. You may have to fudge with the axel a bit to remove, repeat on other side
Remover rubber spring support and install in spring with spacer as shown. repeat on other side
Reinstall both coil springs. You might have to use different jacking points , or pressure on the axel to install the springs w/ the spacers
Jack back up the axel, and reconnect the lower shock mount nut/bolt and sway bar end link. repeat on other side
Reinstall tires, remove the jackstands, your done!
Below is a pic of 5100's @ 2.8, 1.5Body Lift, and the TG 1.5 rear spacers.
MODS: PE Full Metal Jackrabbit, BT Catch can, Magnaflow 18", Vararam, Bullydog Hemi Tuner, Zone 1.5 BL, Bilstein 5100's @2.8, TG 1.5 rear coil Spacers, Fuel 20x10 -12OS, Toyo OC MT 315/60R20, Painted BW Pocket Flares http://www.ramforumz.com/showthread....88#post1344588
Old 02-18-2014, 07:43 AM
012RAMbo's Avatar
012RAMbo 012RAMbo is offline
Vehicle: 2012 Ram 1500 CC
Rep:264
Rep points for the write up and install man! Truck is going to look sick with the new tires and wheels! Great looking truck bro.
Edit: Seems I have to spread some rep around to give you some more, I will get you back!
Cabin Air Filter -Debadged -14" Magnaflow -Mopar T Grip Shifter -Foxbox w/ 10" Type Rs -B Pillar tape removed -Tint matched -CST/Pro Comp 6" Lift - 35x12.50 ATZ P3 and 20x9 +1mm Fuel Mavericks -AMP Power Steps -8k HID -HEMIFEVER Tune
Old 02-18-2014, 12:59 PM
Ryan19 Ryan19 is offline
Vehicle: 2014 Ram Sport Crew 4x4
Trim Level: Sport 4x4
Ryan19 is on a distinguished road
Awesome write up, and perfect timing for me. I've got shocks and a spacer kit sitting in the garage waiting for install. When you put it all back together what torque specs did you use? So far that's the only piece of the puzzle I'm missing.
Old 02-18-2014, 01:12 PM
Vehicle: 2013 Ram
Rep:39
If your installing new shocks the rear upper shock mount is not very accessible, you may have the remove the inner fender liner to avoid busting your knuckles. I used man torque. Im sure something is written for torque specs. Just take your torque wrench and find what the current torque is on the existing hardware before removing.
Old 03-07-2014, 01:04 AM
roggew roggew is offline
Vehicle: 2009 Dodge Ram 1500 CC 4X4
Color: Grey
roggew is on a distinguished road
Hey Boomer, Nice work and nice truck! I am going to add the adjustable bilsteins up front and the regular ones in the back. I was thinking of adding the TGC rear spacer as well. Can I get away with just that? I see you have a body lift on yours as well. Is that necessary? Thanks
Old 09-10-2014, 09:38 PM
EaB's Avatar
EaB EaB is offline
Vehicle: 2009 Ram 1500
Trim Level: Laramie/sport 4x4
EaB is on a distinguished road
with the 1.5" rear spacer do you need bigger shocks??
Old 09-11-2014, 09:59 PM
SK-Ram's Avatar
SK-Ram SK-Ram is offline
Vehicle: 2014 Ram
Trim Level: SPORT
Rep:54
SK-Ram will become famous soon enough
I put a 2" spacer in the rear about 14 months ago, I've had zero issues.
'14 Sport Reg Cab 4x4
'13 SXT 4.7 6" Lift & 35's Gone But Not Forgotten
Old 09-18-2014, 02:42 AM
daviddup78's Avatar
daviddup78 daviddup78 is offline
Vehicle: 2012 Ram 1500 HEMI 4x4
Trim Level: Lone Star
Color: deep cherry red
Rep:71
daviddup78 will become famous soon enough
Looking at your pics and remembering when i did my .75" rear spacers. My spacers are on the bottom. Is that normal also??
2012 Dodge Ram 1500 4x4 with goodies and 6'' Fabtech lift
Old 09-18-2014, 09:52 AM
SK-Ram's Avatar
Vehicle: 2014 Ram
Trim Level: SPORT
Rep:54
Yes, mine was on the bottom and the coil spring was seated right over to the top rim of the spacer.
