United Radio
Old 02-13-2014, 09:00 PM
JasonGriff's Avatar
JasonGriff JasonGriff is offline
Vehicle: 2009 Dodge Ram TRX4
Trim Level: TRX4
Color: Blue and gray
JasonGriff is on a distinguished road
Default Can you add to a 4" bds???
I have a 4" bds and I need just a little more lift for some new wheels and tires. Can I put shims, spacers or shocks to get more out of it.
2009 TRX4 ^ 4" BDS lift^ 35x12.50r20 kumho venture mt ^ 20x10 ^ drop in K&N ^ 3.92's^ 5% TInt
Old 02-13-2014, 09:25 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:1969
brandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant future
You can add some Bilsteins to the front for an extra 2" of lift ( I wouldn't max them out on a lift) and rear coil spacers in the back.
8" BDS Long Arm Lift with Fox 2.0 Shocks | Dual Fox 2.0 Steering Stabilizer | 37x13.5 Toyo MT's | AMP Powersteps & Bedstep | Bakflip G2 | Mag-Hytec Rear Diff Cover
EST 500 hp/1268 ft-lbs at FW | H&S MiniMaxx Custom Tuned | 4" Flo Pro Stainless TBE | Sinister EGR Delete | ARP 425 Head Studs | 4.56 AAM/Yukon Gears | S&B Intake w/ Scoop
Old 03-03-2014, 04:16 PM
JasonGriff's Avatar
Trim Level: TRX4
Do you know the part # for a 09 trx4?
Old 03-03-2014, 04:34 PM
Rep:1969
The Bilstein part number is 24-187367. For rear coil spacers check out Top Gun Customz.
Old 03-03-2014, 04:58 PM
JasonGriff's Avatar
Trim Level: TRX4
thank you. is there a place to order them online that you like?
Old 03-03-2014, 05:28 PM
Rep:1969
I would contact the guys at Bully's Performance at sales@bullysperformance.com. Just let them know that you're a forum member and what you want and they'll get you the best pricing around.
Just a heads up though, the Bilsteins are on a nation wide back order at the moment so you'll probably end up having to wait a while to get them. But they're definitely worth the wait.
Old 03-03-2014, 09:18 PM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
Just checked again as we get closer and closer to them being available but it is still saying later this Month for the bilsteins.
As Brandon stated though they are worth the wait and the best setting would be 2.1 and then a rear coil spacer.
If you would like to get a set ordered feel free to reach out to us via PM or by posting in our Vendor Section, you can also email us directly at sales@bullysperformance.com or call us toll free at 855-432-FAST we are always more than willing to help out forum Members, just remember if you contact us off of the boards to mention you are a Z member to insure you get the best discounts
Thanks
Jeremiah
Old 03-04-2014, 01:05 AM
Vehicle: '15 Ram 1500 EcoD (ordered)
Trim Level: Longhorn: CC, 6'4"
This is good feedback
