Old 02-24-2014, 07:25 PM
vyper340 vyper340 is offline
Vehicle: 2014 Ram 1550 Longhorn Limited
Trim Level: Longhorn Limited
vyper340 is on a distinguished road
What bulb and where did you get the reverse lights in the taillight module?
Old 02-25-2014, 03:10 AM
KA1OTE's Avatar
KA1OTE KA1OTE is offline
Ram Ham
Color: Mineral Gray Metallic
Rep:1475
My reverse tail light bulbs are the OEM stock bulbs that came on my 12. I will be changing them over to LEDs, but haven't yet.
Old 02-25-2014, 11:58 AM
ramryck's Avatar
ramryck ramryck is offline
Vehicle: 2012 dodge ram
Trim Level: sport
Color: cherry crystal
ramryck is on a distinguished road
Your truck looks great and you did a nice job on the harness.
Any problem with the resister hanging? I am adding the led tails to my truck also. I install wire connectors to the resister and harness. This way I can mount the resister keeping the harness PNP. i'm just concerned about the heat the resister gives out and possibly burning something.
But that's me! I attached a couple of photo's of the harness.
Old 02-25-2014, 02:31 PM
Arth's Avatar
Arth Arth is online now
Rep:2028
Sorry for stealing answers here KA1OTE.
I mentioned this to her and I will mention it to you.
I ran this setup for about 8 or so months with the resistor just hanging on my previous truck without issue.
If you want to mount your resistor since you have the right plug and play idea there use the lower portion of the fender.
If the resistor is touching any wires you will have issues. If you put the resistor in the lower portion of the fender and the wires to the apposite side you will not have any problems.
Chrome... in moderation.
Old 02-25-2014, 03:40 PM
ramryck's Avatar
Trim Level: sport
Arth, thanks. I Just don't like things hanging. I would be worried about it. lol
Old 03-05-2014, 09:39 PM
KA1OTE's Avatar
Ram Ham
Rep:1475
No problem, Arth.. thanks for answering when I couldn't get online.
ramryck - I have had my setup installed for about a month now and I haven't had any issues with the resistors. I pulled each tail just for a visibility check and all was well. They are stuffed to the bottom of the wells and are not coming into contact with any of the wires in my homemade looms as there was no visible damage on either side. So mounting the resistors is not necessary, however I can understand doing it your way so you are not bothered or worried by it.
Old 03-06-2014, 12:51 AM
jsl6v8 jsl6v8 is offline
Vehicle: 2013 Ram 1500 HFE
Trim Level: HFE
Color: Patriot Blue- Merica
jsl6v8 is on a distinguished road
Where does the 5013984AA Pigtail Harness's come into play?
Old 03-06-2014, 01:25 AM
Arth's Avatar
Rep:2028
That harness is what plugs into the Tail light side.
That particular part number includes the connector for the tail light and some wiring needed to connect the connectors together for the truck side.
You need two of that part number... one for each side.
Old 03-06-2014, 12:40 PM
Trim Level: HFE
I'm trying to find that part on moparonlineparts.com and when I do a search for 5013984AA it just comes up with the kit, I have the tail lights and just need the pig tails, am I looking in the wrong place?
Old 03-06-2014, 12:42 PM
Arth's Avatar
Rep:2028
I had the same issue. Make sure you search their site using repair parts..not accessories.
It should pop up that way.
