Old 02-21-2014, 12:18 AM
Tshepp Tshepp is offline
Vehicle: 2014 Dodge Ram
Trim Level: Express CC
Tshepp is on a distinguished road
Are the rears necessary on a new truck? I definitely want to level the front but would think I can leave the rear alone. Is that correct?
Old 02-21-2014, 12:27 AM
05cr125r's Avatar
05cr125r 05cr125r is offline
Vehicle: 2012 Big Horn QC
Trim Level: Big Horn 4x4
Rep:94
not necessary....i did just the fronts right after i bought it. damn glad i did too
Mods; Line X, Bilsteins set at 2.1, Magnaflow 18", Debadged , Cool White LED Interior, LED license plate, Cool White LED reverse, Fronts tinted 20 %, Stubby Antenna,AVS WindowVisors, Black Honeycomb Grille Insert, Green Performance Air Filter, SuperChips Flashpaq 3482
Old 02-22-2014, 08:35 AM
sswyers sswyers is offline
Vehicle: 2011 dodge ram outdoorsman
sswyers is on a distinguished road
My bilsteins ride great!
Old 02-22-2014, 07:05 PM
What are most set at: 2.1 or 2.8? I am planning on 2.1 I think just to avoid potential wobble or overdoing it.
Old 02-22-2014, 07:33 PM
Campbell402's Avatar
Campbell402 Campbell402 is offline
Vehicle: 2014 Ram 1500
Rep:73
Campbell402 will become famous soon enough
There's plenty of people here running 2.1 and 2.8. 2.1 can still produce wobble, but it does give you less chance of it than with 2.8. Really depends on how much factory rake you have and how much you want to maintain. For instance, my truck has 3" of rake so I will set mine at 2.8 to level.
Old 02-22-2014, 08:06 PM
h2oman's Avatar
h2oman h2oman is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Express 4X4
Rep:308
There isn't a wobble. At best it is a mild vibration that only happens at take off in 4WD. It doesn't happen in 2WD. Most don't have it. Leveling kits do not cause "death wobble". So put your levels on and have fun.
333Half the beast
I used to be
Old 02-22-2014, 09:33 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
Exactly what he said ^^ Dodge death wobble is on solid axle front ends only. Not 1500's.
Old 02-23-2014, 12:27 PM
Thanks for the info! I guess when mine shows up I will park it and measure the factory rake.
