Old 02-09-2014, 04:04 PM
DaeDae75 DaeDae75 is offline
Vehicle: 2010 dodge ram
Trim Level: Slt TRX
Color: Black.grey
DaeDae75 is on a distinguished road
Exclamation Front differential?!
ok i have a 2003 dodge ram 1500 4x4 4.7l and i had a bad cv axle and replaced it but i still had a grinding noise in my front end my wheel bearings were good and wheels werent hitting anything so i jacked the front tires off the ground and spun my passenger side wheel that had the new cv axle and where the shaft goes in the differential tube it was catching and kinda poping like it was hoping in and out of the splines, and my driver side was even worse my inner cv axle has about 2-3 inches of up and down play i thought my bearings in my front diff might be bad so i pulled my cover found no chipped teeth or missing teeth on my gears but the noise kinda goes away when im in 4wd and does its worse when i turn, so with the wheels off the ground i had somebody spin the driver front wheel while i watched the gears roll nothing caught or jammed or anything but when i shook my cv axle i could see my inner axle that goes in my spider gear moving with it and it was moving my spider gear as well but not a lot and i could see my bearing it had no play what so ever and wasn't missing any bearings anybody have any ideas im desprate lol
