Old 02-08-2014, 09:18 PM
bavedoggs bavedoggs is offline
Vehicle: 2013 RAM 1500 EXPRESS
Rep:15
bavedoggs is on a distinguished road
Default Help...tapped a curb
Well we got snow this weekend and i managed to spin out and tap my rear tire against a curb. No damage to the rim or anything, but I notice the tire now sticks out 1 1/2 inches on the opposite side. (passenger side) Its as if the rear axle shifted. The truck seems to be driving just fine. I got under and there was no apparent damage. I even measured from the caliper in and noticed no difference in measurement between the driver and passenger side. But...like i said, theres a 1 1/2 inch difference in the spacing between the wheel well to the tire compared to the passenger side. Any help is greatly appreciated.
Old 02-08-2014, 10:12 PM
RogerRamJet's Avatar
God Bless Texas!
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
Probably just shifted the weight of the truck in a way that hasn't been done and so now the springs are carrying the load a little different. Try bouncing on the bumper a few times and see if that evens it out.
Old 02-10-2014, 12:22 PM
Rep:15
I jumped around and shook the bed. took it into Les Schwab today and they through it on the alignment rack and confirmed the axle looks shifted to the right. They didn't charge me, just suggested I have it looked at by Dodge. Any ideas? It's not sitting well in my stomach.
Old 02-10-2014, 01:00 PM
easy e's Avatar
easy e easy e is offline
Vehicle: 2007
Rep:21
easy e is on a distinguished road
Do you notice anything different at all when you drive, especially from the rear diff?
Check the u bolts that hold your rear axle in place with the leaf springs. Does everything look square? Has anything shifted? Can you noticed the rear axle moved from where it was clamped in place from the u bolts?
Definitely want to have that looked at.
2007 Hemi SLT 4x4 Quad Cab
260k miles and counting...
Old 02-10-2014, 02:30 PM
rcmpvet's Avatar
rcmpvet rcmpvet is offline
Vehicle: 2014 Ram
Color: Black Gold Pearlcoat
Rep:38
rcmpvet is on a distinguished road
Drive down a freshly covered snow/wet road and then look back at your tracks to see if they are tracking straight.
There Is No Such Thing As A Stupid Question: HOWEVER: Search Function is Your Friend
Old 02-10-2014, 02:58 PM
Rep:15
The gave a complimentary alignment check. said the Thrust was off from the last time i was in. From .09 to .56. They said the wheel and tire were fine/balanced but yet it wobbles. So now I'm wondering if I bent the axle? Basically the drivers side tire now has a wobble and the axle is shifted to the passenger side an inch or so. FML.
Old 02-11-2014, 01:33 AM
Rep:15
Sweet...looked under and see that I've bent the panhard bar. This probably means i hit hard enough to mess up the axle.
Old 02-11-2014, 11:41 AM
canadian.bacon's Avatar
canadian.bacon canadian.bacon is offline
Vehicle: 2014 RAM
Color: Deep Cherry Red
Rep:121
canadian.bacon will become famous soon enoughcanadian.bacon will become famous soon enough
wow, sounds bad. how hard did you hit that curb? I imagine it was pretty hard to make that kind of damage...
Old 02-11-2014, 11:49 AM
Rep:15
That's the big question right? I don't think i hit it that hard. came into a parking lot (faster than I should have) and tapped pretty good. I'm amazed this happened...I'll chock it up to an expensive lesson learned. $335 rear axle. $120 new panhard bar. Labor-$$
Old 02-11-2014, 01:11 PM
Vehicle: 2014 RAM
Rep:121
that's not bad....under 1k for all that, phew
