Old 02-06-2014, 08:37 PM
redrik redrik is offline
Vehicle: 2013 Ram 1500 QC Black Express
Rep:43
redrik is on a distinguished road
Default 2013 2wd Rim Help
I have a 2013 2wd ram QC black edition and i am going to level it with the Traxda 2"/1" kit. I think i am going to pick up some used 305/55/20 terra grapplers.
So my question is for the rims. Im looking at the Fuel Full Blown. I would like them to stick out a little bit but not too much.
http://www.fueloffroad.com/wheel.cfm?id=3948
So which size would work best for me.
20x9 +20
20x9 +01
20x10 -12
20x10 -24
Thanks for the help guys.
Old 02-06-2014, 10:29 PM
012RAMbo's Avatar
012RAMbo 012RAMbo is offline
Vehicle: 2012 Ram 1500 CC
Rep:264
Hey Redrik. Nice choice in wheels and tires! The 20x9 +20 will not fit on the 305 tires without rubbing your control arms, unless you wanted to run a small spacer. If they did fit without rubbing, it would be very similar to stock stance, being that the stock wheels are 20x9 +19 offset. You are going to want the 20x9 +01 offset. This will put your wheels about 3/4" - 1'' outside the fender with those wider tires. Either 20x10 wheel will have you sticking out a good bit and probably more than you want based off the info you gave us. Good luck!
Cabin Air Filter -Debadged -14" Magnaflow -Mopar T Grip Shifter -Foxbox w/ 10" Type Rs -B Pillar tape removed -Tint matched - Rear level - 22'' SRT-10 reps on 305/45/22 nitto 420s -AMP Power Steps - Custom retro headlights
Old 02-11-2014, 08:45 PM
gopackgo69's Avatar
gopackgo69 gopackgo69 is offline
Vehicle: 2014 Ram 1500
Rep:20
gopackgo69 is on a distinguished road
My vote is the -12 offset
2014 4x4 Hemi sport , 3.92, Pro-comp level 2.75", Rear Fox 2.0, 1.5" springs, Diablo 93 Tuned. Toyo AT2 295/65/20
Old 04-23-2014, 01:20 PM
Rep:43
Update:
Thanks for the info guys. I've been away for a while but I'm back looking around. I got the 2" front level installed and it looks great.
I am going to be going for a different look now. I am going to try to give my truck the race truck look. I am going to be using a 305/50/20 nitto 420. And I will install the rear spacer to give it the rake back.
My concern is how much the tires should stick out. I will eventually get the stock fender flares.
I am torn with the wheels. I really love the look of the Fuel Formula. I would get a 20x10 -18. The only problem is I don't know if I can get the look I want with those wheels.
If not I will go with bmf SOTA stealth 20x9 0mm offset.
Any input will help.
Thanks
